VideoHelp.com Forum
Results 1 to 13 of 13
  1. Member dudeman316's Avatar
    Some subtitles I have put on dvd's or divx files or other video types play back odd.
    For instance, an italicized word will display <i >words </i > like HTML
    & instead of music notes, I get #.
    Is there a fix for this? So that they display correctly
    Father knows best.
  2. Member dudeman316's Avatar
    no one is able to help with this one?
    Father knows best.
    How do you play? software player? vsfilter or ffdshow? divx dvd player? OR HOW?
    I use vsfilter on my computer and I'm just using srt subs or sub/idx.
  4. Member dudeman316's Avatar
    I have a few options I use to play:
    1.) I will convert Divx/Xvid to DVD using TMPGEnc DVD Author 3 with DivX Authoring & add subs that way & get this problem.
    2.) Burn Divx/Xvid to DVD as Data & play back on both my standalone players.
    3.) Same deal with my WD tv hd media player (which is a nice little device)
    Father knows best.
  5. Banned
    The actual problem is, some (if not all) hardware players don't support
    the HMTL-styling for .srt files. Use idx/sub instead.
  6. Member dudeman316's Avatar
    is there a program that I can use to convert that you would recommend?
    Father knows best.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    I would probably just remove html tags, maybe some subtitle can do that or google for html strip tags.
  8. Member dudeman316's Avatar
    what about music notes when there are songs? Is it html as well?
    Father knows best.
  9. Banned
    Probably that character doesn't exist in the font(s) used by the player.
    Midzuki is quite right. Many hardware players don't support HTML-styling and music symbols in SRT files. I just used WordPad or OpenOffice Writer (a clone of Microsoft Word) to remove such things from my SRT files. Too much trouble otherwise.
    dudeman316 - I know it would be nice to have this stuff work, but are you REALLY going to insist that you can't live without this? It doesn't hinder understanding to not have a music note or italics in subtitles.
  11. Member dudeman316's Avatar
    thanks all for the replies, I can do fine without the music notes & all that, I just didnt want html code on the screen & I will just got through & remove them
    Father knows best.
    If you change your mind, I used Subtitle Creator to correct .srt files I had created using CCExtractor and convert them to .sups (for DVD authoring with IFOEdit). Music and italics in the edited .srts came out fine in the .sups.
    If you don't change your mind, Subtitle Workshop allows text editing via search and relpace (Subtitle Creator only has search), but won't convert .srts to .sups.
  13. As I remember reading last year music notes (symbols) are a problem. You may have to use special ANSI font symbols. Many subtitle programs that work with srt use ANSI and not Unicode, UFT-8 but not sure.
    Can someone provide more details of possible solutions?
  1. Subtitle problems using convertxtodvd
    By gtorres001 in forum Authoring (DVD)
    Last Post: 3rd Mar 2012, 01:36
  2. Subtitle problems
    By Mrs Cee in forum Newbie / General discussions
    Last Post: 8th Sep 2010, 18:09
  3. Subtitle problems
    By neroman00 in forum Subtitle
    Last Post: 30th Dec 2009, 03:15
  4. Problems with Subtitle Workshop
    By Jomapil in forum Newbie / General discussions
    Last Post: 20th Jan 2009, 15:17
  5. Subtitle problems
    By artistguy68 in forum ffmpegX general discussion
    Last Post: 27th Jan 2008, 19:40
