Basically, I want to take a DVD movie and rip it to an ISO file.
For some reason is goes very slowly! I have also done a simple 'cat /dev/scd0 > image.iso' and it too is very slow. The DVDROM drive never spins up.Code:dd if=/dev/scd0 of=/home/user1/image.iso 557177+0 records in 557176+0 records out 285274112 bytes (285 MB) copied, 76.3168 s, 3.7 MB/s
I can do this w/ DVD-Decrypter and WINE, but DVD Decrypter goes very slowly (1.7x-2.0x) too. I know it's not my hardware because this same machine booted into XP does this operation around 12-14x in DVD-Decrypter. Also, k3b is dog-slow writing an iso.
Any ideas why it's so slow? Thanks all!
http://encoding.n3.net <-- for all your DVD and CD backup needs!
DMA issue? Libata being forced for a not fully supported chipset?
You can try booting with libata.atapi_enabled=1 added to your kernel.
--edit--
Using dd to copy an encrypted DVD doesn't always work. If the DVD is using a newer encryption with bad block methods, the drive can be forced to do a re-read and perform error correction. Should this happen too many times, the drive will turn off dma to save itself. You can use K9Copy, vobcopy, mplayer dump stream, Vamps, or something else, but not dd on encrypted DVDs.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
Software that will allow to see what bitrate a movie or iso file is encoded
By Teac23 in forum DVD RippingReplies: 6Last Post: 21st Apr 2010, 19:22 -
How to burn 8.3G iso movie file to dvd double layer disc?
By ibearzz in forum DVD RippingReplies: 12Last Post: 21st Oct 2007, 19:47 -
change the subs on a movie iso file
By bigboy77 in forum SubtitleReplies: 4Last Post: 17th Sep 2007, 14:11 -
Editing Movie from an ISO file
By z93007 in forum Authoring (DVD)Replies: 3Last Post: 16th Jul 2007, 16:03
Statistics
Newest guides
Latest tool updates
New media comments
