VideoHelp.com Forum
Results 1 to 15 of 15
    I have 4 external hard drives. 3 of 4 work fine. I've been having problems with my cavalry HD which is 1TB. I can play the movies on my pc but when I try to burn them It fails usually midway through. This started today and I have already wasted 8 dvds so far. When the dvd is burning there are times where it will pause for a second or two then continue on. Sometimes it will say estimated time is an 1 hour when it usually take minutes to burn. I bought this 2 months ago and the warranty is up. Any advice would be greatly appreciated. Thanks
  2. if you can play them, you might be able to copy them off to another drive. sounds like that one is dying. just a guess but it is probably a seagate hard drive inside, they have been dropping like flies. 2 months is awfully short for a warranty, when a bare drive is usually 1 or 3 years. i'd take it apart, remove the drive and see who made it and run their diagnostic software on it over a usb-ide/sata adapter cable. you may be able to return it directly to the drive manufacturer that way.
  3. VH Wanderer Ai Haibara's Avatar
    You might post a log from your burning program showing one of the failed/bad burning attempts. (If you're using Nero, or any other software that posts the program's serial number in the log, be sure to edit it out, first.) Maybe there's an indication there as to what the problem is.
    Are you using quality disc media to burn?
    You may also be having issues with the HDDs tripping over each other. Not all USB drives play nicely together.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    I use Ridata and Taiyo yude.. They have worked fine before Here is a log below.
    4/10/2009 5:29:49 AM info Sending anonymous statistics...
    4/10/2009 5:29:49 AM info Finalizing...
    4/10/2009 5:29:49 AM error Write error recovery failed at 1315088 (16) - Code 03 0C 00 [Write error]
    4/10/2009 5:29:49 AM info Try #593 - duration 1358 µs
    4/10/2009 5:23:57 AM info Lead-in burning time (mS) 12
    4/10/2009 5:23:57 AM info Start Write Buffer
    4/10/2009 5:23:57 AM info Start writing...
    4/10/2009 5:23:57 AM info Drive Timing: DMA Mode
    4/10/2009 5:23:57 AM info Buffer under-run proof enabled
    4/10/2009 5:23:57 AM info Writing speed requested x8.0, effective x8.0
    4/10/2009 5:23:57 AM info Writing session #1 and closing disc.
    4/10/2009 5:23:57 AM info Open Image file "C:\Documents and Settings\Administrator\Application Data\CopyToDvd\COPYTODVD_04102009_052356_765.cache"
    4/10/2009 5:23:57 AM info Required sector size : 1658624
    4/10/2009 5:23:57 AM info Available sector size : 2295104
    4/10/2009 5:23:57 AM info Available write speed: 16x, 12x, 8x, 6x, 4x
    4/10/2009 5:23:57 AM info Media ID: RITEK-F16-01
    4/10/2009 5:23:56 AM info Volume name: "08"
    4/10/2009 5:23:56 AM info 120mm DVD
    4/10/2009 5:23:56 AM info Detected media $001B : DVD+R
    4/10/2009 5:23:56 AM info Finished browsing files - Data size 3.16 Gb.
    4/10/2009 5:23:56 AM info File scan complete: 27 files, 2 directories
    4/10/2009 5:23:56 AM info Start Browsing file structures
    4/10/2009 5:23:56 AM info IDE Controler manufacturer : (Standard IDE ATA/ATAPI controllers)
    4/10/2009 5:23:56 AM info IDE Controler Description : Standard Dual Channel PCI IDE Controller
    4/10/2009 5:23:56 AM info Location : PCI bus 0, device 18, function 0
    4/10/2009 5:23:56 AM info Location : PCI bus 0, device 20, function 1
    4/10/2009 5:23:56 AM info Support Media : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    4/10/2009 5:23:56 AM info Writing device used : 2:0:0 - PIONEER DVD-RW DVR-115D 1.18 [D] (Ide)
    4/10/2009 5:23:56 AM info Using Patin-Couffin driver Version 1.37, Internal revision 37 - Async. Access mode
    4/10/2009 5:23:56 AM info Using DVD Video filelist creation mode.
    4/10/2009 5:23:56 AM info ParamStr 4 = "/writespeed=8.0"
    4/10/2009 5:23:56 AM info ParamStr 3 = "/writedevice=D"
    4/10/2009 5:23:56 AM info ParamStr 2 = "/volumename=08"
    4/10/2009 5:23:56 AM info ParamStr 1 = "/dvdvideofl=C:\Documents and Settings\Administrator\Application Data\Vso\~c2c_fl.tmp"
    4/10/2009 5:23:56 AM info ParamStr 0 = "C:\PROGRA~1\VSO2\COPYTO~1\CopyToCD.exe"
    4/10/2009 5:23:56 AM info User default language : 1033 (0x0409h) - English (United States)
    4/10/2009 5:23:56 AM info System default language : 1033 (0x0409h) - English (United States)
    4/10/2009 5:23:56 AM info Version 4.0.4.60
    4/10/2009 5:23:56 AM info ExeName : "C:\PROGRA~1\VSO2\COPYTO~1\CopyToCD.exe"
    4/10/2009 5:23:56 AM info OS : Microsoft Windows XP Professional Service Pack 3 (Build 2600)
    4/10/2009 5:23:56 AM info 32 bits native system
    4/10/2009 5:23:55 AM info ******************** Report session started ********************
    The log above is from a program I use 90% of the time called copytodvd. I tried nero and everything burns fine. I find this odd, because I never had problems burning files with copytodvd from this hard drive. Does anyone know why this is? All along I thought the problem was with the hard drive.
  6. Always Watching guns1inger's Avatar
    So it only fails to burn with one burning application ?
    Have you also tried imgburn ?
    If Nero and Imgburn work, then the problem is most likely CopyToDVD. I would start by a simple uninstall, reboot, reinstall and see if that has any effect.
    I reinstalled copytodvd and burned over 5 discs succesfully until all of a sudden the last 2 burns failed. I tried imgburn and nero and the same thing happens with those. I've wasted close 20 discs already. Even the files on my internal hard drive fail to burn. Are there any solutions. I posted my copytodvd and nero logs.
    Windows XP 5.1
    IA32
    WinAspi: -
    NT-SPTI used
    Nero Version: 9.0.9.100
    Internal Version: 9, 0, 9, 100
    Recorder: <PIONEER DVD-RW DVR-115D>Version: 1.18 - HA 1 TA 0 - 9.0.9.100
    Adapter driver: <IDE> HA 1
    Drive buffer : 2000kB
    Bus Type : default
    CD-ROM: <JAREJEZ 5A7G5Q78D6VG >Version: 1.03 - HA 1 TA 2 - 9.0.9.100
    === Scsi-Device-Map ===
    CdRomPeripheral : PIONEER DVD-RW DVR-115D atapi Port 2 ID 0 DMA: On
    CdRomPeripheral : ATAPI DVD A DH20A4P atapi Port 2 ID 1 DMA: Off
    DiskPeripheral : SAMSUNG SP0802N atapi Port 3 ID 0 DMA: On
    CdRomPeripheral : JAREJEZ 5A7G5Q78D6VG 1.03 a92h20uw Port 4 ID 0 DMA: Off
    CdRomPeripheral : JAREJEZ 5A7G5Q78D6VG 1.03 a92h20uw Port 4 ID 1 DMA: Off
    === CDRom-Device-Map ===
    PIONEER DVD-RW DVR-115D D: CdRom0
    ATAPI DVD A DH20A4P E: CdRom1
    JAREJEZ 5A7G5Q78D6VG I: CdRom2
    JAREJEZ 5A7G5Q78D6VG L: CdRom3
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    BUFE : 0
    Physical memory : 1726MB (1767920kB)
    Free physical memory: 1188MB (1217500kB)
    Memory in use : 31 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    11.4.2009
    UDF/ISO compilation
    7:24:48 AM #1 Text 0 File SCSIPTICommands.cpp, Line 450
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    7:24:50 AM #2 Phase 112 File dlgbrnst.cpp, Line 1767
    DVD-Video files reallocation started
    7:24:50 AM #3 Phase 114 File dlgbrnst.cpp, Line 1767
    DVD-Video files reallocation completed (no file modified)
    7:24:50 AM #4 Text 0 File Isodoc.cpp, Line 6789
    UDF document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : FALSE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    UDF Mode : UDF/ISO bridge
    UDF Options : automatic
    UDF Revision : 1.02
    UDF Partition Type : physical
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : FALSE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    7:24:50 AM #5 Phase 111 File dlgbrnst.cpp, Line 1767
    DVD-Video files sorted
    7:24:50 AM #6 ISO9660GEN -11 File Geniso.cpp, Line 3349
    First writeable address = 0 (0x00000000)
    7:24:50 AM #7 ISO9660GEN -11 File Geniso.cpp, Line 3349
    7:24:51 AM #8 Text 0 File Burncd.cpp, Line 3563
    Turn on Disc-At-Once, using DVD media
    7:24:51 AM #9 Text 0 File FilesystemSettingsValidator.cpp, Line 142
    FS Settings: using validator 'CUDFSettingsValidatorDVD'
    ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
    Changing UDF revision from '1.02' to '1.02'
    7:24:51 AM #10 ISO9660GEN -11 File Geniso.cpp, Line 3349
    7:24:51 AM #11 ISO9660GEN -11 File Geniso.cpp, Line 3349
    7:24:51 AM #12 Text 0 File DlgWaitCD.cpp, Line 312
    Last possible write address on media: 2295103 (510:01.28, 4482MB)
    Last address to be written: 2174463 (483:12.63, 4246MB)
    7:24:51 AM #13 Text 0 File DlgWaitCD.cpp, Line 324
    Write in overburning mode: NO (enabled: CD)
    7:24:51 AM #14 Text 0 File DlgWaitCD.cpp, Line 2951
    Recorder: PIONEER DVD-RW DVR-115D, Media type: DVD+R
    Disc Manufacturer ID: <RITEK>, Media Type ID: <F16>, Product revision number: 1
    Disc Application Code: 0, Extended Information Indicators: 7
    7:24:51 AM #15 Text 0 File DlgWaitCD.cpp, Line 499
    >>> Protocol of DlgWaitCD activities: <<<
    7:24:51 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 756
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 2174464 (2174464) = #2174464/483:12.64
    relocatable, disc pos for caching/writing not required/ required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2174464 blocks [D: PIONEER DVD-RW DVR-115D]
    7:24:52 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 958
    Prepare [D: PIONEER DVD-RW DVR-115D] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc not fixated
    Tracks 1 to 1: Idx 0 Idx 1 Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4453302272, ISRC ""
    DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
    0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 1 | 0x41 | 2174464 | 0 | 0x00
    2174464 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    7:24:52 AM #18 Text 0 File SCSIPTICommands.cpp, Line 240
    SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
    7:24:52 AM #19 Text 0 File Burncd.cpp, Line 4362
    Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
    7:24:52 AM #20 Phase 24 File dlgbrnst.cpp, Line 1767
    Caching of files started
    7:24:52 AM #21 Text 0 File Burncd.cpp, Line 4484
    Cache writing successful.
    7:24:52 AM #22 Phase 25 File dlgbrnst.cpp, Line 1767
    Caching of files completed
    7:24:52 AM #23 Phase 36 File dlgbrnst.cpp, Line 1767
    Burn process started at 6x (8,310 KB/s)
    7:24:52 AM #24 Text 0 File ThreadedTransferInterface.cpp, Line 2675
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    7:24:52 AM #25 Text 0 File Cdrdrv.cpp, Line 10187
    ---- Disc Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+R (10), Part Version: 1.0x (1)
    Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26053F h
    Data in Burst Cutting Area (BCA) does not exist
    Disc Application Code: 0 / 0 h
    Extended Information indicators: 7 h
    Disc Manufacturer ID: RITEK...
    Media type ID: F16
    Number of Physical format information bytes in use in ADIP up to byte 63: 56
    Media Specific [16..783]:
    00 00 07 52 49 54 45 4B - 00 00 00 46 31 36 01 38 ...RITEK...F16.8
    23 54 37 12 02 50 6E 02 - 8C 68 16 16 0B 0B 0A 0A #T7..Pn..h......
    01 1D 1E 0C 0C 12 12 01 - 00 00 00 00 00 00 00 00 ................
    01 00 38 38 02 2D 62 1E - 08 2E 23 10 04 1E 1D 01 ..88.-b...#.....
    00 00 02 2D 62 1E 08 2E - 23 10 04 1E 1D 01 00 00 ...-b...#.......
    02 00 54 70 02 38 64 24 - 30 18 10 10 01 20 00 00 ..Tp.8d$0.......
    00 00 02 48 60 2A 30 18 - 10 10 01 20 00 00 00 28 ...H`*0........(
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    7:24:52 AM #26 SPTI -1066 File SCSIPassThrough.cpp, Line 215
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
    CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x24
    Sense Qual: 0x00
    Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
    Buffer x048eb480: Len x648
    7:24:52 AM #27 Text 0 File DVDPlusRW.cpp, Line 675
    Start write address at LBA 0
    DVD high compatibility mode: No
    7:24:52 AM #28 Text 0 File ThreadedTransfer.cpp, Line 273
    Pipe memory size 83836800
    7:24:53 AM #29 Text 0 File Cdrdrv.cpp, Line 1411
    07:24:53.802 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:23 AM #30 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:23.442 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:23 AM #31 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:23.520 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:23 AM #32 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:23.942 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:24 AM #33 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:24.052 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:24 AM #34 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:24.255 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:24 AM #35 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:24.270 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:24 AM #36 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:24.286 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:24 AM #37 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:24.302 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:24 AM #38 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:24.317 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:24 AM #39 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:24.333 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:24 AM #40 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:24.348 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:24 AM #41 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:24.583 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:24 AM #42 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:24.661 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:25 AM #43 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:25.848 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:25 AM #44 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:25.927 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:28 AM #45 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:28.270 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:28 AM #46 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:28.333 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:28 AM #47 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:28.739 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:28 AM #48 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:28.802 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:30 AM #49 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:30.005 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:30 AM #50 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:30.083 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:32 AM #51 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:32.302 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:32 AM #52 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:32.380 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:32 AM #53 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:32.880 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:32 AM #54 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:32.973 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:33 AM #55 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:33.161 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:33 AM #56 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:33.177 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:33 AM #57 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:33.192 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:33 AM #58 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:33.208 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:33 AM #59 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:33.223 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:33 AM #60 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:33.239 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:33 AM #61 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:33.255 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:33 AM #62 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:33.270 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #63 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.161 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #64 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.239 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #65 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.411 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #66 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.427 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #67 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.442 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #68 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.458 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #69 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.473 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #70 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.489 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #71 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.505 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #72 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.520 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:34 AM #73 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:34.536 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:36 AM #74 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:36.427 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:36 AM #75 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:36.520 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:36 AM #76 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:36.708 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:36 AM #77 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:36.723 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:36 AM #78 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:36.739 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:36 AM #79 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:36.755 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:36 AM #80 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:36.770 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:36 AM #81 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:36.786 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:36 AM #82 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:36.802 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:36 AM #83 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:36.817 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:40 AM #84 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:40.723 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:40 AM #85 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:40.770 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:41 AM #86 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:41.177 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:41 AM #87 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:41.239 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:41 AM #88 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:41.567 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:41 AM #89 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:41.630 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:42 AM #90 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:42.036 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:42 AM #91 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:42.098 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:43 AM #92 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:43.286 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:43 AM #93 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:43.348 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:43 AM #94 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:43.520 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:43 AM #95 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:43.536 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:45 AM #96 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:45.536 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:45 AM #97 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:45.614 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:49 AM #98 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:49.817 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:49 AM #99 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:49.911 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #100 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.052 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #101 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.067 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #102 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.083 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #103 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.098 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #104 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.114 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #105 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.130 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #106 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.145 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #107 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.161 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #108 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.177 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #109 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.192 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #110 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.364 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #111 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.427 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #112 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.833 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:50 AM #113 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:50.911 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:52 AM #114 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:52.083 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:52 AM #115 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:52.145 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:54 AM #116 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:54.348 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:54 AM #117 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:54.411 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:58 AM #118 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:58.614 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:58 AM #119 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:58.677 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:58 AM #120 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:58.864 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:58 AM #121 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:58.880 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:58 AM #122 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:58.895 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:58 AM #123 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:58.911 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:58 AM #124 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:58.927 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:58 AM #125 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:58.942 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:58 AM #126 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:58.958 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:58 AM #127 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:58.973 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:25:59 AM #128 Text 0 File Cdrdrv.cpp, Line 1411
    07:25:59.020 - D: PIONEER DVD-RW DVR-115D : Queue again later
    7:28:51 AM #129 SPTI -1135 File SCSIPassThrough.cpp, Line 215
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
    CDB Data: 0x2A 00 00 0A 1B 60 00 00 20 00 00 00
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    Sense Area: 0x71 00 03 00 0A 18 80 0E 00 00 00 00 0C
    Buffer x093f3f00: Len x10000
    0x00 00 01 BA 44 30 44 F2 4C 55 01 89 C3 F8 00 00
    0x01 E0 07 EC 81 00 00 03 E0 B9 BA 22 67 00 00 01
    0x19 22 D3 C1 CB 34 D5 9B 04 14 86 68 28 81 36 60
    7:28:51 AM #130 CDR -1135 File Writer.cpp, Line 306
    Write error
    7:29:16 AM #131 SPTI -1061 File SCSIPassThrough.cpp, Line 215
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1061)
    CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00
    Sense Key: 0x04 (KEY_HARDWARE_ERROR)
    Sense Code: 0x44
    Sense Qual: 0xD6
    Sense Area: 0x70 00 04 00 0D 10 1C 0E 00 00 00 00 44 D6
    7:29:41 AM #132 SPTI -1061 File SCSIPassThrough.cpp, Line 215
    CDB Data: 0x5B 01 02 00 00 00 00 00 00 00 00 00
    Sense Code: 0x44
    Sense Qual: 0xD6
    7:29:41 AM #133 Text 0 File DVDPlusRW.cpp, Line 943
    EndDAO: Last written address 662368
    7:29:41 AM #134 CDR -1061 File WriterStatus.cpp, Line 292
    Internal target failure
    7:29:41 AM #135 TRANSFER -24 File WriterStatus.cpp, Line 292
    Could not perform end of Disc-at-once
    7:29:41 AM #136 Text 0 File DVDPlusDualLayer.cpp, Line 1424
    SetDriveCaps: Set LAST LBA of layer 1 to 0
    7:29:42 AM #137 Phase 38 File dlgbrnst.cpp, Line 1767
    Burn process failed at 6x (8,310 KB/s)
    7:29:42 AM #138 Text 0 File SCSIPTICommands.cpp, Line 287
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    7:29:46 AM #139 Text 0 File Cdrdrv.cpp, Line 11444
    DriveLocker: UnLockVolume completed
    7:29:46 AM #140 Text 0 File SCSIPTICommands.cpp, Line 450
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    4/10/2009 5:23:57 AM info Open Image file "C:\Documents and Settings\Administrator\Application Data\CopyToDvd\COPYTODVD_04102009_052356_765.cache "
    I forget to mention, I have two dvd writers and burns fail in both.
  9. DVD Ninja budz's Avatar
    That's your problem RITEK is considered crappy low grade dvd media. Try using VERBATIM OR TAIYO YUDEN dvd media.
    ok, i tried my taiyo yuden disc yesterday and they worked. Today, i tried burning a few discs and they failed or the software says it is going to take 1 hour to burn. I have 2 burners and both do this.
  11. check all your drives and make sure they are in dma mode, not downgraded to dual fifo which will happen if windows sees too many errors in a row.
    Thanks for your reply. All drives are in DMA mode. The first 2 taiyo yuden discs I used failed within the first 10 seconds of burning, then the next 8 were succesful. I then burned my ridata and they burned successfully but my dvd player did not recognize them. So I guess those 2 packs I got were just bad batches? I bought 4 100 pack ridata and the first batches burned great. The first 20 or so of the 3rd batch burned and played well, but the rest failed. $40 down the drain I never had problems ridata discs in the past. I then burned some more taiyo yuden discs and one failed at the start like the other two. I find this odd, since Taiyo is very reliable and already I have 3 failed burns out of like 12. It makes me think that the issue is not with the taiyo media. Why do the burns fail right at the start?
  13. DVD Ninja budz's Avatar
    Are you multitasking when burning dvd media? Make sure you turn off all programs running in the background when burning dvd media. Such as firewalls, antivirus and spyware programs. Running programs in the background can affect the burning of a dvd disc.
    Where did you purchase your TY discs? Over the years there have been reports of some online retailers selling fake TY.
    Buy a new 80 wire ide cable for your PIONEER 115 drive. IDE cables have known to fail after a period of time.
    Use IMGBURN to burn all your dvd media. Is your PIONEER 115 in a external enclosure or is it installed in your computer case? Big difference if you're using it in a external enclosure. Not all external enclosures will work with PIONEER drives.
    I do not multi task while burning. I've been buying from newegg for a while now. I check my media with dvd identifier and they are real. They are TYG03 and I still has some TYG02 from shop4tech. newegg is the cheapest and shipping is extremely fast. I will buy the 80 wire ide cable online today. The Pioneer is installed in my computer case.
  15. Member [_chef_]'s Avatar
    Looks like usb crappo devil stroke again.
    I hate usb............
    *** Now that you have read me, do some other things. ***
  1. Playing 720 movies from Hard drive to tv with usb help!
    By Cupid Stunt in forum Newbie / General discussions
    Last Post: 15th Jan 2011, 00:25
  2. Play full blu-ray movies on ps-3 from hard drive
    By jim49 in forum Software Playing
    Last Post: 7th Apr 2010, 18:54
  3. moving my home movies to an external hard drive
    By medicaldawg in forum Media
    Last Post: 11th Dec 2009, 09:55
  4. I have a BD370- need to hook up hard drive and play movies
    By explosivo in forum DVD & Blu-ray Players
    Last Post: 17th Nov 2009, 17:51
  5. Replies: 11
    Last Post: 23rd Jun 2009, 16:54
