I usually use VirtualDub to get screenshots from a video for every 500 frames but virtualdub can't open mkv files. Is there any other program that can open mkv files and take screenshots of every 500 frames?
Results 1 to 9 of 9
Thread: Grab screenshots from video
Try virtualdubmod or try Video Thumbnails Maker.
I can't see an option to set how many frames to screen capture in video thumbnails maker
I've always used MPC. But I don't know if it's adjustable.
Google is your Friend
MPC only does thumbnails. I wanted full size screenshots of every 500 frames
You could probably do it with AviSynth using SelectEvery() and ImageWriter().
I've never tried to open .mkv in AviSynth, but I'm sure there's a way."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
You can also open it up with an avisynth script in virtualdub. You need avisynth & the proper splitters & decoders installed (e.g. haali media splitter, ffdshow). Just write the text file, rename extension to .avs. Open the .avs in virtualdub
DirectShowSource("movie.mkv")
VLC does a good job on screen grabs as well. It also helps smooth interlaced frames so the image doesn't suffer from interlaced artifacts.
modify any of the presets (select-modify, save)Originally Posted by Shaorin
Grab old VHS video cassettes
By knuno in forum LinuxReplies: 1Last Post: 21st Feb 2011, 13:13 -
Please help me download/grab this video.
By lucygurrll in forum Newbie / General discussionsReplies: 8Last Post: 23rd Aug 2010, 21:58 -
is there any way to grab this particular video?
By Razvan007 in forum Video StreamingReplies: 10Last Post: 9th Feb 2010, 14:50 -
Can I grab the video from a Divx Web Player?
By Deaks in forum Video ConversionReplies: 5Last Post: 26th Sep 2007, 20:43
