I'm trying out Premiere Pro Cs4 and I have made a very simply edited video, when trying to export, even using the default compression settings, after hitting ok, a very quick dialog/progress bar box comes up that says "exporting data" and finishes, and my rendered video is not where it is supposed to be. any ideas on why i can not export my movie?
Results 1 to 9 of 9
Did you check the adobe media encoder queue?
In CS4, it doesn't encode directly out of Premiere anymore
ah thank you very much sir, my questions are answered.
Hey,
I think I have another problem here.. I am working with WIN7 and adobe premiere pro CS4 and I have edited a very simple short video. Now I am having troubles with exporting the thing. When I export it, the win media encoder opens but (of course after starting and finishing the queue) no file comes out :S
I can't figure out where the problem is because I nearly tried everything now.. Could anybody please give me a hint? I am quite new in the video-editing busines.. =(
thanks in advance =)
cc
Did you mean adobe media encoder? or windows media encoder ?When I export it, the win media encoder opens but (of course after starting and finishing the queue) no file comes out :S
Have you tried other export formats?
This is abnormal behaviour
Did you try uninstalling / reinstalling CS4 ?
not yet, but maybe there will be no other way.. =(
thanks for your support =)
Perhaps the trial version is not exporting all formats?
Exporting Premiere Pro CS4 Project - Adobe Media Encoder question
By schmickers in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jan 2012, 18:51 -
Premiere CS4 lossless exporting
By timwizard in forum EditingReplies: 7Last Post: 16th Feb 2010, 09:49 -
Random freeze or stop while exporting to tape in Premiere Pro CS4
By LghtAndDrk in forum EditingReplies: 1Last Post: 8th Jul 2009, 00:51 -
Exporting AVCHD from Premiere Pro CS4
By jodal in forum Video ConversionReplies: 14Last Post: 29th May 2009, 07:12 -
Problem exporting xvid/divx with Premiere CS4
By moogleii in forum EditingReplies: 2Last Post: 23rd Mar 2009, 19:18
