Hello fellas. You've helped me a lot in the past , and i hope somebody can help me this time also.
This is probably terribly simple question to ask. I have a camcoder, that records mpeg-2 files on to built-in hard drive.
When I connect it to a computer - I see a list of .MOD files. Here is the description of the file in mediainfo.exe:
I also know that these files are compatible to dvd, because there is a "create dvd" button on the camera.Code:Complete name : N:\1\MOV028.MOD Format : MPEG-2 Program Format/Family : MPEG-2 File size : 454 MiB PlayTime : 8mn 17s Bit rate : 7655 Kbps Video #0 Codec : MPEG-2 Video Codec profile : Main@Main Codec settings/Matri : Custom PlayTime : 8mn 17s Bit rate : 8400 Kbps Bit rate mode : CBR Width : 720 pixels Height : 576 pixels Aspect ratio : 4/3 Frame rate : 25.000 fps Standard : PAL Chroma : 4:2:0 Interlacement : Top Field First Bits/(Pixel*Frame) : 0.810 Audio #0 Codec : AC3 PlayTime : 8mn 17s Bit rate : 384 Kbps Bit rate mode : CBR Channel(s) : 2 channels Sampling rate : 48 KHz Video0 delay : -80ms ChannelPositions : L R
When i put these files in Nero REcode, it recognizes them as video and lets me create Dvd-video out of them, but it is re-encoding them , which takes us huge amount of time, and deminishes the quality of the files.
How can I create standard Dvd video out of these files without reencoding them?
[/code]
Arguing with an idiot, make sure he isn't doing the same
Try other authoring tools like Tmpgenc Authoring Works should not reconvert or some free dvd authors like DVDStyler, GuiForDVDAuthor or the simple DVD FLick(be sure to enable so it does not reconvert in the settings).
Many authoring tools (like GfD) will want you to demux the video to a separate video and audio (AC3) file.
(This is not reencoding, just rearrangnig the same data, so no quality loss and quite fast.)
Then they will recombine them in the correct way to make a DVD.
Find demuxers here: http://www.videohelp.com/tools?toolsearch=demux
BatchDemux is simple and free.
Baldrick, Thanks for your help. I'm downloading Dvd Flick right now. Will see how it goes. Will report back
AlanHK, Videos are already using Mpeg-2 program stream, they only have .mod and not .vob extension. I work with virtual dub and mkv tools. They can demux almost any video, but need to know which container to demux to? Or you mean raw video and audio files?Arguing with an idiot, make sure he isn't doing the same
authoring programs usually need to work with separate streams. as in .mpv and .ac3 and will demux the .mpg into them for you. if the program doesn't like the .mod extension change it to .mpg and it should work.
What minidv2dvd said. Just change the extension to .mpg if your authoring program doesn't recognize the .mod extension. Demux if needed.
One of Nero's worst habits is wanting to unnecessarily re-encode.
If you can stop the re-encoding, you might get Nero to work for you correctly. If not, just use a proper authoring program, then burn with ImgBurn to a DVD disc.
Separate video and audio files. Eg. video as .m2v, audio as .ac3.Originally Posted by junglemike
Some authoring apps will work with combined audio-video, but separate ones are more compatible.
Join video files without reencoding and save/load order of videos
By Danielyt in forum EditingReplies: 6Last Post: 1st Nov 2011, 11:27 -
Cut HD files (h264/avc) without reencoding
By cd090580 in forum EditingReplies: 3Last Post: 25th Jun 2010, 18:37 -
Video files recorded on my camera won't play
By sskkdeckman in forum Newbie / General discussionsReplies: 15Last Post: 30th Nov 2009, 18:02 -
16:9 DVD video - how to get the original format without reencoding?
By Weef in forum RestorationReplies: 6Last Post: 22nd Sep 2009, 08:33 -
What to do with large AVI video files taken on my digital camera?
By scormodo in forum Newbie / General discussionsReplies: 9Last Post: 30th Aug 2009, 11:13
