Hi everyone at the great videohelp.com site!!
I have recently bought a Blu-ray reader(pioneer) to my computer and I want to start ripp Blu-ray, convert it somehow to .WMV files with burned in subtitle, so that I would have only one .wmv file with subtitle in it or else I can't play it on my mobile phone and other devices that supports .wmv I'm not microsoft fan, but I just want it to be in wmv files.
I've noticed that AnyDVD HD is the software for Blu-ray, HDDVD and DVD ripping. ISn't it? So I tried it out and it worked great. I accessed the folder found several .m2ts files, figured out that the biggest one probably would be the movie file. I played it up in MPC, found out that this type of files contains several movie angles, sounds in several languages, and allot of subtitles. I tried this with mamma mia.
So next think was to continue reading in the forum and search for guides to achieve what I was looking for. I found an explaination that I can separate the contained .m2ts and extract whatever I want and leave out the rest that I don't need. And I used the tsMuxer from the smartlabs, which works great, but I've not figured out what all the functions are.
So I extracted the movie and got a file in ".vc1" another file in ".dts" and the last in ".sub" I know that the sub is subtitle, the .dts is the sound and the .vc1 probably is the motionpicture.
So, how should I now move forward to mux it(that's what it's called right)? Or whatever the way is,
To make one .wmv file with the burned in subtitle?? I want to make files in 1-2GB/hour I think that's the compressed 720p "outhere".
Balderick recommended subrip to convert the .sub to .srt files, is that really necessary?
If you want burned in subs you don't "mux" it, you must reconvert it. But I don't think you will find an all-in-one solution for m2ts with subs to wmv encoding, maybe AutoMKV(free) or something like Total Video Converter($$). Or else maybe convert the m2ts with burned in subs to mp4 using Ripbot264 and then reconvert the mp4 to wmv using Encode360.
But do you really have a mobile phone with 720p wmv video support?!?
Thanks for the answer.
Actually my phone doesn't support the 720P. Reason that I want to make it 720P is to save space on my HDD because 30-40GB for a movie is allot of space for me, 4-8GB would be ok, and I don't have a veryvery big tv anyway. But it's nice to have it in HD.
And burning in subtitle is for mobile phone. Of course it would be much smaller, I don't wanna buy both a dvd and a blu-ray to compress like that. Right now I'm usin imtoo dvd ripper to make movies for my mobile but it doesn't support the blu ray encoding.
Are you sure that total video converter support m2ts conversion to wmv? does it work with subtitle also?
TVC claims to support m2ts but I have not tried it.
Or try HDConvertToX. Not so simple but should work.
You could use avisynth + WMNicEnc. You must know the basics of avisynth to do this method. I would use tsmuxer to generate the main movie and main audio in .m2ts
For the subs, you can convert the image based .sup to text based .srt using suprip or supread, or it might be easier to download from a subs database, because some OCR will be involved. You would then use textsub() to hardsub
Or you could use BDSup2Sub, which will convert to idx/sub format similar to DVD subs. Then you could use vobsub() to hardsub
This is for burned in subs, not selectable (muxed in) subs
thanks for the answer, I've already muxed it into .mvk files with everything I want. Now I need to convert the mkv file to ".wmv" file. And I'm looking for some good application for doing that. I want to keep the 5.1 channels also.
Originally Posted by poisondeathray
You can use vc12avi , avi-mux gui, solveig asf muxer, +/- windows media stream editor
Read this thread (maybe start from the end)
http://forum.doom9.org/showthread.php?t=119785
I think you will lose your subs, because they are not burned in
Issues with Blu Ray Players and Burned DVDs?
By mizmelzy in forum DVD & Blu-ray PlayersReplies: 5Last Post: 20th Mar 2011, 04:45 -
Only getting L and R audio from PS3 (burned DVD and blu ray)
By tikigod19 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 4th Feb 2011, 08:03 -
Burned blu ray on standalone player, I have audio but no video
By BAMFstang in forum Authoring (Blu-ray)Replies: 2Last Post: 19th May 2010, 13:28 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
blu ray to wmv-hd?
By eao1 in forum Blu-ray RippingReplies: 7Last Post: 15th Jun 2008, 16:45
