Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. Member Snakebyte1's Avatar
    Mar 2002
    Ontario, Canada
    Hi...
    I'm trying to configure a Toshiba SD-V395KC DVD/VCR Combo unit to work with a Bell ExpressVu 3100 Satellite Receiver.
    In the receiver's VCR Configuration it requires the manufacturer's 3 digit code. However I have not been able to find one that works. Code 616 works when programming the remote control but doesn't work for the receiver.
    I was just wondering if anyone has either had any luck configuring a 3100 receiver to work with the SD-V395KC or if anyone has found/used a different Toshiba 3 digit code that works for their receivers.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The code is determined by the remote manufacturer. So whichever remote you are trying to program is the manufacturer you need to contact to get the code list.
    Google is your Friend
