VideoHelp.com Forum
    I have an SH-S223Q DVD burner, that according to what I've read, has something called Riplock. I understand there is a patch that will disable this. Where can I locate this patch? I have a Philips SPD2513 20x burner, & it can burn a +DL disc at 4x, while the Samsung tops out at 2.5x since I updated the drive'sfirmware to SB03 from SB00 yesterday.
    Any help with this is greatly appreciated.
  2. DVD Ninja budz's Avatar
    Go to the SAMSUNG FORUM at CDfreaks.com. Do some research or join their forum and you can post your questions there. I haven't flashed a SAMSUNG drive since their model S203B. You could also use MEDIA CODE SPEED EDIT to get the drive to rip at faster speeds.
    http://ala42.cdfreaks.com/MCSE/
    I saw something about Media Code Speed Edit, but I'm not sure how to install it it & I'm also not sure that it will work with the new SB03 firmware update. I'll check out that link you mentioned. I'm already a member I believe, but I haven't been there in a while. Many thanks
  4. DVD Ninja budz's Avatar
    It's not hard to use MCSE. Ala's website explains how to use it.
  1. Disabling auto-play
    By videohalp in forum DVD & Blu-ray Players
    Last Post: 19th Jan 2012, 09:28
  2. Disabling Divx De-interlacing
    By Sliztzan in forum Editing
    Last Post: 8th Jun 2011, 23:19
  3. Help with Disabling Subs by Default
    By TheAlmighty in forum Subtitle
    Last Post: 16th Dec 2009, 03:52
  4. Samsung DVD writers differences (SH-S223Q/BEBD vs SH-S223Q/BEBS)
    By TheWolf1 in forum DVD & Blu-ray Recorders
    Last Post: 11th Aug 2009, 15:34
  5. DVD+RW @ 8x with TSST H653L anyone??
    By MilesAhead in forum DVD & Blu-ray Writers
    Last Post: 12th Jul 2007, 17:05
