Hello there,
I been using this software to authoring my blu-ray movies, but i have a problem.
When i trying to resize movies like harry potter, hellboy, the mummy to dvd-dl9 in full backup, i got this message from bd-rebuilder when its processing extras with vc-1 format....
this example is from the movie Hellboy 2: the golden army:
09:45:49] PHASE ONE, Encoding
- [09:45:49] Collecting video information [00292]
- Video: 1920x1080, 29,970fps
- Bitrate: 3.132 Kbs
- [09:45:49] Reencoding: VID_00292, Pass 1 of 2
- Encode failed. Retrying.
- Reached retry limit. Aborting.
[09:46:39] - Failed video encode, aborted
when this appears it pop up a window with the message "x.264 has detected an error and it must shut down" and i click it "don't send", and on the third try abort the entire process...
I have the latest bd-rebuilder.... fddshow....haali media splitter....windows media player 11, and i don't know what it's going on???![]()
I have an intel q6600 processor running on XP SP3.... perhaps it's my graphics card??? i don't have an hd card... i have an ATI x1650 pro 512mb graphics card.
Can someone give an advice??? thanks....![]()
Renato
Did you ever get an answer to your question? I have the same problem.
FunCo
And the name of the movie is?
Also, have you done any rebuilds with BDRB successfully, or is this your first try?
A couple points:
1) You must use the recommended versions of ffdshow and haali splitter. Available in the first post here:
http://forum.doom9.org/showthread.ph...hlight=inspect
2) Check your configuration. In the BDRB folder is a little app called "inspect.exe". Run it and post the results here.
3) Problems with encoding VC-1 are often caused by Haali splitter. Either a wrong version is being used or there is residual junk left from uninstalling an incorrect version. After uninstalling an incorrect version and *BEFORE* installing the correct version, you should delete the Haali folder in Programs.
Good luck and welcome to the forums.
Pull! Bang! Darn!
I should have added:
4) Uncheck "Quicker encode for extras".
5) If you're re-sizing the extras, that can be a problem as well (often caused by the subtitles). After trying all of the above, uncheck the resize for extras and/or deselect all but one subtitle track.Pull! Bang! Darn!
Overclocking can sometimes cause that error. If your overclocking,drop to default speed and try again.
From the go I had two good burns. Then I tried "Gone with the Wind” that’s when I started getting the error messages.
I deleted and reinstall everything, and then I follow all your instructions. I ran inspect and then I fix the errors that it noted.
VC-1 to WMV9 and MPEG 2 to liBmpeg2. Everything is working fine.
To everyone reading this, the big secret is to run the very cool inspect.exe file. Then just follow the simple to understand instructions.
I really appreciate the Forum's help.
BD Rebuilder stops encoding
By pepegot1 in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jun 2011, 10:01 -
Bd Rebuilder Failing on Encoding
By Westie69 in forum Blu-ray RippingReplies: 4Last Post: 31st Mar 2011, 02:52 -
BD Rebuilder: ERROR "failed video encode, aborted"
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 22nd Feb 2011, 18:57 -
BD Rebuilder v0.34.11 Failed video encode, aborted
By jairtonfs in forum Blu-ray RippingReplies: 3Last Post: 7th Oct 2010, 12:08 -
Deleting Extras with BD Rebuilder
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 27th Dec 2009, 23:10
