I've been using this DVD player for a few months, it's amazing, I connect my external HD and it plays everything. I came home tonight and tried to watch an avi file, turned it on, and the screen menu on TV became oranged (normally is blue), looks like something is wrong, i don't know how to describe it. I tried to play an AVI file and it's unwatchable, it still plays it, but the picture quality was very bad, colors are all wrong. THen I tried to play a regular DVD, same thing. What happened??
I tried watching plain tv and it's fine, so it must be the DVD player! Help!
How do you have the 5990 connected to the TV? Have you tried connecting it using a different method, to see if the picture still appears orange using those other connections? You might also try connecting it to a different TV, to see if the problem does persist.
Not much info to go on. ie... How is it connected? Other than using the usb and playing one disc, what have you tried already before posting this?
Anyway when my Philips dvp5990 acted up (not the same symptoms) I just unplugged it (not just the off button) for a few minutes and it reset. You could try that.
Another option is to change the video cable or try another connection. ie... if it's on hdmi or component try composite and see it that corrects it which might point to a faulty cable. If there are multi inputs on the tv then switch the wires around see if the symptoms change.
The more specific info you give the easier it is to offer help.There's not much to do but then I can't do much anyway.
Oh, sorry, I didn't give alot of info. It is connected to the TV via HDMI cable. I only turned it on and off, have not tried using different cable. Husband not home, I have no idea how the cables work!! I will try unplugging and plug it back in hopefully it'll reset it. Oh, I think there are 2 HDMI slots on the TV, so maybe I can try that.
I don't have anything else connected to the TV other than this to test. (well, does cable box count?
Oh my god, unplugging and plugging back in fixed the problem!! Why didn't I think of that! Thank you!!
Edit
Since it's resolved then ignore the following which I wrote while you posted.
Since it's connected via hdmi and it worked ok before then the cable itself is the least likely culprit. I don't have mine connected to an hdtv but there are options in the player's menu "Video setup page" specific to hdmi setup. Maybe those settings have been changed. I can't view those since I don't use hdmi but you may want to look at that.Originally Posted by fayewolfThere's not much to do but then I can't do much anyway.
Can't get Philips 5990 to fill the screen on HDMI
By ahhaa in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Jun 2010, 09:13 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 16:06 -
Slideshow with Philips 5990
By indyram in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Dec 2008, 19:55 -
Philips 5990
By mis3 in forum DVD & Blu-ray PlayersReplies: 12Last Post: 2nd Nov 2008, 17:12 -
Distorted color on playback?
By Nathan1 in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2008, 20:21
