VideoHelp.com Forum
    Hi
    Recently I bought this Philips 5996 but I am unable to play large files via USB. Is there any file size limit via USB? Can I play large files via disc?
    The file I tried to play was encoded with XVID & is 2.4 GB, .avi format. I am herewith enclosing the GSpot specifications of the video file for your reference just in case.
    And is there any difference if I write my DVDs on +R or -R so that the player could deliver better results?
  2. Member edDV's Avatar
    File size is limited to 4GB (FAT32)
    Your raster size is too big @1280x576. Max is near 720x576.
    Also VBR audio encoding may be an issue.
    http://www.kiva.org/about
  3. Max size of 4gb per file. No hi-def stuff (above 720x576).. qf of 096 is crummy
    The electronic components of the power part adopted a lot of Rubycons.
    Thanks for the replies guys. But http://forum.videohelp.com/topic354707.html suggests QF is of no use. And as it says the video I posted is absolutely of extreme clarity but QF is disappointing.
    And from the 720x576 thing, I understand that when they say that this is the best [1080i] HDMI player, it should probably be upscaling videos from 720x576 to the 1080p...Am I right?
    Are there any DVD players that can actually play HDs directly @ 1080 pixels?
    Regards
    N Deepak.
  5. Always Watching guns1inger's Avatar
    Very few. Perhaps some of the Oppos might. If you want playback of HD material, try a WDTV unit instead of a DVD player. Even the BluRay players that support Divx playback (not many of them do) are SD limited.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  6. Member edDV's Avatar
    Regards
    N Deepak.
    Divx has a list of certified HD players. The players use the Sigma 8xxx series codecs and are priced new over $200. Some manufacturers are I-O Data, Buffalo, KISS, etc.
    http://www.videohelp.com/dvdplayers?...Submit2=Search
  1. Replies: 18
    Last Post: 17th Oct 2011, 01:03
  2. Easycap usb large capture files
    By visionman in forum Capturing
    Last Post: 4th May 2010, 17:23
  3. Replies: 4
    Last Post: 21st Mar 2009, 12:34
  4. USB HD - EX2 or NTFS support with large file
    By Robcio in forum DVD & Blu-ray Players
    Last Post: 5th Feb 2008, 10:23
  5. Replies: 5
    Last Post: 19th Dec 2007, 01:36
