VideoHelp.com Forum
Results 1 to 15 of 15
    IVE JUST HAD A NEW PC AND WHEN I TRY TO REGISTER ITS SAYING I HAVE REACHED MY LIMIT SO NOW I CANT USE THE PROGRAM EVEN THOUGH I ONLY HAVE ONE PC,I HAVE E-MAILLED THE SITE 3 TIMES BUT NO REPLY AND I DONT KNOW WHAT TO DO NOW,I HAVE ALSO CHANGED MY E-MAIL FROM WHEN I BROUGHT THE PROGRAM SO NEED THAT CHANGING TOO.
    I HAVE MY OLD E-MAIL ADDRESS AND SERIAL THOUGH STILL.
    PLEASE HELP !!
  2. ChrissyBoy is in hospital at the moment. Please be patient and he will resolve this once he is released. Drop him a PM with your registration info.
    Also check your "caps lock" key, it seems to be stuck.
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  3. Member ChrissyBoy's Avatar
    Gosh that was loud... Yes i had an unforeseen op last night but should be back at the helm after the weekend, early next week.
    However you maybe able to register without me as you will automatically give you a new one once 60 days up on any of 3 lics,
    I Know but its still not registering thats probaly because i kept wiping my hard drive and reinstalling because of a virus so have used up all my licenses,i have pmd you my serial num and my old e-mail address can you reset my license if poss and give my instructions to change my e-mail address to my new one too.
    thx in advance.
  5. Member ChrissyBoy's Avatar
    I am in hospital at the moment. I will ask my wife to reset you tonight.
  6. ChrissyBoy, you go above and beyond...
    Dwight
    - Herm Albright
  7. Member ChrissyBoy's Avatar
    This should be sorted now. Can you confirm?
    Yeah its sorted thx,Can you send me details on how to change my e-mail address,Can you send to my new e-mail address supernovauk@hotmail.co.uk thx
    I'm sure it just slipped the posters mind to wish you a speedy recovery !!
  10. Member ChrissyBoy's Avatar
    - hoping to be out by the weekend....
  11. Originally Posted by Diggerboy
    Dwight
    - Herm Albright
    I hope you're well soon, and everything is okay.
    I just upgraded to the newest version and build of SVCD2DVD, and now it requires a reg code. I do not have Internet access at home. As part of the displayed message when I run the new currently unregistered version of SVCD2DVD, it says, "Pressing "Cancel" now or at anytime will allow you to register manually using a reg code you have obtained from www.svcd2dvd.com"
    I can not find how to do this anywhere on the website, and I NEED IT NOW. If I would have known this was going to happen, I would not have uninstalled the old version, and I would have waited until I got all I needed beforehand. But there was no warning of this anywhere that I saw. Perhaps you should add it somewhere, like in the message displayed while installing the new version, that says you must uninstall the old version first. tell them to make sure either they have Internet access, or to obtain the reg code first. And most importantly, explain how to obtain the reg code manually, as that is my problem now.
    Please tell me how to obtain a reg code so I can use the program. I have stuff I needed to have done already, but can't do until I get the reg code.
    Thanks.
  13. Member ChrissyBoy's Avatar
    I have responded to your email about this.
    recently had a virus on my pc so had to reformat so i have used all of my licenses i have my serial number and machine license but need to change my email address and when i try and register with my machine code the registration box opens up i put the code in and it does nothing any help would be greatfully appreciated and i hope you are now feeling better after your op ChrissyBoy
  15. Member ChrissyBoy's Avatar
    Getting better thanks. Drop me an email/PM and I'll help you get it registered.
    CB
  1. + in email address - won't register
    By swmcdonnell in forum SVCD2DVD & VOB2MPG
    Last Post: 6th Jul 2009, 08:08
  2. Replies: 10
    Last Post: 21st Jun 2008, 16:33
  3. Cant register
    By eddier528 in forum SVCD2DVD & VOB2MPG
    Last Post: 7th Jan 2008, 03:33
  4. Can't register
    By gussi86 in forum SVCD2DVD & VOB2MPG
    Last Post: 1st Oct 2007, 09:33
  5. Changing my IP address?
    By Akabane Kurodo in forum Computer
    Last Post: 7th Jul 2007, 08:28
