I've run into an issue with converting my videos to FLV format.
The conversion seemed to complete, but I could not get the videos to display. First I thought that there was an issue with the flv player that I used (vlc), but soon I realized that the source of my problem was the conversion itself.
During the conversion I always use the Terminal window. I noticed that before the conversion completed, there was an error message complaining about "flvtool2".
After some Googling in this topic I found out that FLV videos have some metadata and that this data is required to play them properly. As far as I understand flvtool2 is responsible for attaching this data to the video data.
For some reason, and maybe that is how this was intended to be, ffmpegx does not install flvtool on the system. At least it did not install it on mine. I had to manually install it.
The installation is very simple. It required only three lines of Terminal code. But first download flvtool from the following site (click on the View all files, and then download the latest files "flvtool2-1.0.6.tgz"):
http://rubyforge.org/projects/flvtool2/
You will need to uncompress the package. Then open up a Terminal window and navigate into the uncompressed flvtool folder.
Then type in the following 3 commands to install flvtool2 (by the way I just copied these commands from flvtools2 README file):
You will see a bunch of mambo-jumbo flying by, which will hopefully mean that flvtool was installed on your system. If you are curious where it installed the files, look for the file called "InstalledFiles" in the flvtool folder.Code:ruby setup.rb config ruby setup.rb setup sudo ruby setup.rb install
After I did this, ffmpegx was able to complete the FLV video conversion and my videos finally played without any issues in VLC. And not only VLC, but I was able to post them on my site and play them with an online FLV player.
I hope that this will be helpful for some...
Results 1 to 1 of 1
FLV won't play correctly in another computer
By kfain in forum Video ConversionReplies: 6Last Post: 29th Dec 2011, 12:10 -
Problem converting h264 to FLV
By Andrea_Barghigiani in forum Video ConversionReplies: 3Last Post: 30th Mar 2011, 13:34 -
Problem converting megavideo flv
By maddogandnoriko in forum Video StreamingReplies: 1Last Post: 13th Sep 2010, 14:35 -
Problem converting mov to flv with ffmpeg
By zigune in forum Video ConversionReplies: 8Last Post: 15th Jul 2009, 02:03 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video StreamingReplies: 9Last Post: 30th Apr 2008, 22:09
