Just wondering whether anyone can help me - I was told by a sales man @ a store that I can get a code that I can use to convert my portable dvd player so that it plays DivX. Can someone please confirm or deny and if yes where can I get this code from? Thanks
Thread: How to play DivX on DVD player
The unit will need to play divx files. A code would not help. What model # is it? Do a Search on Google and it will tell you if it will play divx files.
Good Luck And Welcome to the Forum
I think the salesman was referring to DivX VOD (Video On Demand). Your device has an 8-10 character code which you use to register your DivX certified player in order to rent or purchase DivX movies from any licensed VOD partner. Typically, you'll find the VOD code in the setup menu of your device.Originally Posted by justda6ofus
Here are a couple links with further information....
http://vod.divx.com/
http://vod.divx.com/howitworks.php
You do not need the VOD code for an Divx movies you create yourself.
The salesman is a dumbass.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Divx playback requires a special processing chip that either your portable player has or it doesn't. If it has it, no special code should be necessary. If it doesn't have it, no special code will work.
Both lordsmurf and philips599037 have provided reasonable explanations for this. You'll have to figure out which is correct. If your manual (you do have the manual for the portable, right?) says nothing about Divx play back, then lordsmurf has nailed it.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 6Last Post: 20th Mar 2012, 10:22 -
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 24Last Post: 31st Jan 2012, 07:07 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Does a Divx DVD player play xvid?
By Gerrich in forum Video ConversionReplies: 6Last Post: 22nd Feb 2009, 01:36 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
