  1. So I received my registration key this morning and copy-pasted it in the "Enter Code" menu during the splash screen along with my name.
    All looks fine until I close it and re-open it and it's still notifying me that I'm using the shareware and a code must be entered. Tried the code without the hyphens, tried to re-install it..........no success.
    I e-mailed the developer and awaiting a response.
    Has anyone else had this issue?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    This issue is mentioned once before.
    Make sure to enter both the Name and Code exactly as provided in the e-mail, especially with regard to case-sensitivity. The name and code are linked, hence you should use the same name as used for registration, when you requested the key.
  3. I wasn't aware that the name could affect the registration.
    Thanks a lot, it now works perfectly
