for some reason i cant play DV videos
I have a mov video. i opened it with Gspot and said
File Typ: RAW DV - IEC 61834 (.DV)
Codec: DV/DVC
Status:Codec Status Undetermined
I tried opening this with VLC player. TMPGENC 4.0 XPress even Quicktime and wont play
Dont know if its a codec issue or what.
If so what codec should i download. or how can i fix this problem? so i can play the video and edit it
Try mpeg streamclip and avidemux.
Thanks but i tried to open it with mpeg streamclip and it says
File Open error: unsupported file type
you might try the enosoft dv product. iifc it reads raw dv, and then you could output dvavi type I or II.
I get a "could not load codec settings" with Fairuse Wizard
By felix in forum DVD RippingReplies: 3Last Post: 29th Apr 2011, 11:10 -
Netflix "wait" status problem
By JohnnyBob in forum Newbie / General discussionsReplies: 27Last Post: 21st Dec 2010, 23:22 -
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 11Last Post: 22nd Mar 2010, 14:37 -
HELP -- need to find codec for "*.VSR" file...
By SimdudeS in forum Newbie / General discussionsReplies: 6Last Post: 3rd Aug 2007, 18:39
