VideoHelp.com Forum
Thread: Sound hicups
    I use svcd2dvd to make DVD's from avi files I've been noticing I get little glitches in the sound about avery 15 or 20 minutes
    I thought it was in the source but its been too consistant with a number of different movies any ideas what coud cause this? Using lates ffdmeg codecs, if that helps
  2. Can you attach a log from one of these hiccuping runs?
    What is your playback device(s)?
    What kind of DVD media?
    What burn speed do you use?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    play back device Sony Blu-ray player
    DVD-R media
    8x
    I'll have to see if I can capture a new log file typically delete them after conversion
    doing one tonight will attache later
    Correction burn speed was 3x using Imgburn
    Here is log file
    australia.log-0.log
  5. I have had the same issues on HD players. The DVD plays fine in a regular DVD player - can you try it in one to verify that the issue is the same as mine?
    ChrissyBoy is aware of it but we deferred a fix as I was the only one experiencing the problem at the time
    Dwight
    - Herm Albright
  1. Replies: 0
    Last Post: 19th Jan 2012, 21:03
  2. 3d video with dts sound how to convert to ac3 sound
    By fredddiemercury in forum Video Conversion
    Last Post: 2nd Nov 2011, 14:54
  3. Replies: 1
    Last Post: 15th Apr 2011, 14:29
  4. Replies: 18
    Last Post: 30th Oct 2010, 11:58
  5. Replies: 2
    Last Post: 24th Jun 2007, 18:01
