VideoHelp.com Forum
  1. I'm not even sure what you call it but it is the text of the spoken words that runs below the film. I have an avi movie that has annoying foreign subtext running. Is there any way to get rid of it?
    Start by playing the movie in a player like VLC or The KM Player. if the subtitles are soft-subs embedded in the video you will be able to turn them off during playback. If you can, try using AVIMuxGUI to remove them.
    If you cannot turn them off then they are hard-subs, encoded as part of the video. There is no nice way to remove them. Your options in the case are
    1. Leave them. No further damage is done to the video.
    2. Use a filter such as Delogo or MSU Subtitle Remover to replace the subtitles with an annoying blurry blob instead. You will also have to re-encode the video, potentially reducing the quality.
    3. Crop the section with the subtitles off, then re-encode. You lose some of the image, but you don't get the blob. You still risk losing image quality when you re-encode.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Greetings Supreme2k's Avatar
    4. If available, buy or rent the DVD. It's well worth it, quality-wise, to have a legit copy, rather than a hard-subbed (probably) torrented copy.
  4. Originally Posted by guns1inger
    If you cannot turn them off then they are hard-subs, encoded as part of the video. There is no nice way to remove them. Your options in the case are....
    VirtualDub MSU Subtitle Remover latest version might just work good enough for you. Try it and see how well it works for you.
    http://www.compression.ru/video/subt.../index_en.html
    If you plan on overlaying a new translated soft coded or hard-coded subtitle, that might even further reduce any blurring effect
  1. How to remove subtext from movie
    By striker9 in forum Authoring (DVD)
    Last Post: 12th Aug 2010, 04:06
  2. System Running Slow when running dvdshrink
    By mn072065 in forum Computer
    Last Post: 24th Mar 2009, 19:59
  3. Running counter in XVID movie?
    By drwho in forum Editing
    Last Post: 12th Oct 2008, 03:21
  4. How to simply turn off MKV subtext
    By hanugro in forum Editing
    Last Post: 18th Nov 2007, 03:49
  5. Cn't get the textsub / subtext in VirualDubMOD
    By download in forum Subtitle
    Last Post: 18th Jun 2007, 19:22
