VideoHelp.com Forum
    Some time ago you kindly arranged SVCD2DVD to convert dvr-ms files. I used it for a while and all went fine.
    I haven't had any need for a bit, and then went to do a conversion once again. The dvr-ms file (recorded by Media Center off Freeview) makes the odd claim of being NTFS at 59.94 fps. (SVCD2DVD says that, Windows properties says 59 fps and does not say the format). When converted by SVCD2DVD to .mpg format it does not play correctly (too fast with bad artefacts, even though the file size is similar to the original). The original is fine when played by (for example) VLC or Windows Media Player.
    Any ideas? Thanks, Stephen
  2. Did you meant NTSC?
    Can you attach your log file here?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Thanks for quick response. Yes, I meant NTSC (silly me). I include a (truncated) log that should have all you need.
    I posted (or meant to post) an addenda early this morning, but it does not seem to have made it (I probably forget to press 'send'?) ....
    I tried with various bits of software such as VLC and ffmpeg and they failed too in various ways. Several could play but not convert (no output or corrupted output). Finally, I did get a sensible conversion with the ffmpeg in the current version of DVRMSToolbox. The command line that generated was ...
    C:\Program Files\DVRMSToolbox>"C:\Program Files\DVRMSToolbox\Applications\Ffmpeg\ffmpeg_MPGM UX.exe" -y -i "xxx.dvr-ms" -vcodec copy -acodec copy -f dvd "xxx.mpg"
    log from that for info in case it helps .... maybe the critical hint is
    "Seems stream 1 codec frame rate differs from container frame rate: 25.00 (25/1) -> 50.00 (50/1)"
    "C:\Program Files\DVRMSToolbox\Applications\Ffmpeg\ffmpeg_MPGMUX.exe" -y -i "xxx.dvr-ms" -vcodec copy -acodec copy -f dvd "xxx.mpg"
    FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
      configuration: --enable-static --enable-memalign-hack --enable-libmp3lame --enable-libxvid --enable-gpl --enable-libfaad --enable-libfaac --enable-pthreads --enable-liba52 --disa
    ble-ffplay
      libavutil version: 49.4.1
      libavcodec version: 51.40.4
      libavformat version: 51.12.1
      built on Jul 27 2007 15:35:02, gcc: 4.2.1
    Input #0, asf, from 'H:\recorded tv\The No. 1 Ladies' Detective Agency_BBC ONE_22_03_2009_20_58_01.dvr-ms':
      Duration: 01:04:58.5, start: 0.000000, bitrate: 5082 kb/s
      Stream #0.0: Audio: 0x0000, 48000 Hz, stereo, 256 kb/s
      Stream #0.1: Video: mpeg2video, yuv420p, 720x576, 15000 kb/s, 50.00 fps(r)
    Output #0, dvd, to 'xxx.mpg':
      Stream #0.0: Video: mpeg2video, yuv420p, 720x576, q=2-31, 15000 kb/s, 25.00 fps(c)
      Stream #0.1: Audio: 0x0000, 48000 Hz, stereo, 256 kb/s
    Stream mapping:
      Stream #0.1 -> #0.0
      Stream #0.0 -> #0.1
    Press [q] to stop encoding
    frame=23822 fps=3276 q=130674.2 Lsize=  565466kB time=953.0 bitrate=4860.6kbits/s
    video:523016kB audio:29768kB global headers:0kB muxing overhead 2.294226%
    svcd2dvdlog-20090328101933-short.txt
  1. WTV/DVR-MS files into usable MPEG format?
    By CursedLemon in forum Newbie / General discussions
    Last Post: 24th Jul 2010, 09:21
  2. Conversion of DVR-MS to Standard Mpeg2 Format
    By jaffacaique in forum Video Streaming
    Last Post: 13th Apr 2009, 04:40
  3. conversion from vhs video to Pioneer 520 DVR to Computer friendly format
    By newguy23 in forum Newbie / General discussions
    Last Post: 9th May 2008, 02:32
  4. graphedit conversion from dvr-ms
    By docsquash in forum Video Conversion
    Last Post: 27th Jan 2008, 17:03
  5. Windows Media Center dvr-ms format
    By todds1 in forum SVCD2DVD & VOB2MPG
    Last Post: 15th Sep 2007, 03:37
