I used to have some freeware software that would let me load DVD cover artwork, select a template, and it would create a 3D rendering of the DVD, like this (note, this is a 14 VCD set, but you get the idea):
I can't seem to find it now. I am not even sure of what to search for in Google. But I seem to remember trying several free ones out and deciding on that one.
Darryl[/img]
Thread: 3d Virtual DVD cover
I have this one & used to use this one all the time.
Does exactly what your photo is.
http://www.imandix.net/
Download IMANDIX Cover Professional to make virtual product shots of your CDs, DVDs, Blu-Ray and HD-DVDs, Books, Magazines, Paul Champagne Designer Boxes, Software Boxes and Posters.In the "Downloads" section.Click here to get IMANDIX Cover Standard (Freeware) version. Only DVD cases are supported.
P.S.
You do know you can get every episode of those now in way better quality then vcd 8)Originally a member since 2001, LONG LIVE TARAN's!!!
Thanks for the suggestion. I am checking into it right now.
Yeah, I actually have them all on DVD now. But that cover was the only example I had handy of that cover software.Originally Posted by Noahtuck
Darryl
This is it! You found the exact program. Thanks! Here is what I just made.
Darryl
Nice artwork.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
You can also do this using the gimp which is freeware but its a manual task where user manipulates images.
@lodrsmurf, Thanks. I tried to keep it in the same spirit as the VHS set. Read more about it here:
http://atlas.kennesaw.edu/~dhirschl/boop/
@Bjs, Yes, I have and use The Gimp. And I know I could've done this using The Gimp, but I wanted the automagic solution.
Darryl
dvd cover desing
By ht0160 in forum CapturingReplies: 1Last Post: 26th Jan 2010, 15:54 -
Dvd Cover Size?
By Denvers Dawgs in forum Newbie / General discussionsReplies: 8Last Post: 4th Aug 2009, 18:05 -
How do I print out a DVD cover?
By orfajackson in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2009, 14:33 -
dvd cover to icon
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2009, 11:21 -
where to find DVD cover ?
By ktnwin in forum MediaReplies: 6Last Post: 11th May 2007, 16:28
