VideoHelp.com Forum
    Hi.
    Can you point me some nice tools (more than one) that can cut/join VCD and *.dat files?
    Thanks.
  2. I'm a Poll Super Moderator johns0's Avatar
    Look to the left of the page menu and you will see How to...edit and there will be your answer,best place to start before asking for help.
    Ben Johnson-I didnt take any stereos!
  3. Banned
    Also, better extract the MPEG tracks with IsoBuster if you intend to
    go thru no headaches.
    Cheers,
    \ Me.
    Operating directly on .dat files is a bit tricky. The best option is to convert to "regular" .mpg first (this is fast and doesn't degrade quality at all; no encoding is involved). VCDEasy will do this just fine (and the free version is all you need). Then use, e.g., TMPGEnc, whose tool set includes a simple cutter/splicer. Again, the free version is all you need, since you are operating on MPEG1 streams. VCDEasy will then happily re-author as a VCD for you (if that's what you want), and create ready-to-burn bin/cue images. Burn with your favorite tool, and you're done.
    Later edit: I should mention that, if you are trying to splice together two streams at other than I-frame boundaries, you can encounter difficulty. Some trimming may be necessary to fix this (TMPGEnc's editor is I-frame aware, so it will automatically trim at the right points, setting you up nicely for a subsequent splice). Timecode breaks can also be a problem. If so, MPEGStreamclip (again, free) will fix that for you. It also can be used to perform simple cuts and splices, although it seems to produce a slightly noncompliant stream that causes problems with some authoring tools. The cure then is to demux and remux with TMPGEnc.
    Unless you need a truly seamless splice, it might be better to author the VCD with the separate streams kept as separate titles. Specify the minimum delay between them, and you can get pretty close to a continuous transition between them. This is what I do most of the time. Saves a lot of work, reduces the need for aspirin.
    Hello, people! Thanks for help.
    I'll try these programs too: Zealot Video Workshop and ImTOO Video Editor
    ---> http://www.zealotsoft.net/video-workshop.htm (this is nice for converting: not to cut as I thought)
    ---> http://www.imtoo.com/video-editor.html
    I have tested TMPGEnc and this program worked nice too.
    Best regards.
    I have used some programs that can help too:
    ---> http://www.vcdcut.com/ ( VCDCut Pro)
    ---> http://www.vcd-cutter.com/ ( VCD Cutter) / Version: VCD Cutter 1.0
    ---> http://www.softpedia.com/get/Multime...D-Cutter.shtml
    In my case, the first one does it works. 8)
    thanks.
  1. mpeg4-ts - how to edit? Need to cut fragments and join two files
    By relu84 in forum Newbie / General discussions
    Last Post: 18th Jan 2011, 07:01
  2. Easiest way to cut and join video files
    By zammil in forum Newbie / General discussions
    Last Post: 15th Oct 2010, 12:04
  3. Good program from cut/join .mpg .wmv files.
    By Beautiful Alone in forum Editing
    Last Post: 27th Jul 2009, 16:57
  4. Replies: 1
    Last Post: 12th Dec 2008, 21:17
  5. VOR files - how do I handle these ?
    By Bansaw in forum Video Conversion
    Last Post: 21st Jun 2007, 11:19
