Hi,
I am looking for the best way to rip from DVD so I can then edit in either premiere or movie maker.
I have tried several options but none seem to work properly. some are not recognised by the editing software some have sound out of sync etc.
What format should I be trying to rip the DVD to to then be able to edit?
I have just ripped to .avi but premiere wont open the file.
Any help or ideas would be greatly appreciated
Thanks in advance
Pete
Thread: DVD to Premiere and movie maker
'All Men Die Not All Men Truly Live'
What kind of editing are you wanting to do? If you are just wanting to cut out portions you need to look for a simple frame accurate mpeg editor like womble mpeg video wizard. Neither Premiere or movie maker natively open MPEG files.
depending on what types of edits you are doing, you might be able to get away with never having to re-encode, therefore not losing any quality.
Ripped to avi? What program? what video and audio codec.
Some of the latest editors can import dvds like mpeg video wizard, vegas and probably latest premiere. But they might not support ac3,dts audio.
I use avidemux to convert to avi, open the first main vob, select yes to append all vob files, under video choose mjpeg or dv-avi, under audio choose pcm/wav and save as avi.
Hi Grey,Originally Posted by greymalkin
I have several movies I have had professionally made and I want to do some cutting and adding to them so adding sound and extra clips from the original DV tapes. I just don't want to go back to the expense of having the producers do it.
Yes, I own all the footage and copyrights. (before anyone asks)
Cheers
Pete'All Men Die Not All Men Truly Live'
Hi Baldrick,Originally Posted by Baldrick
To be honest I cant remember what I used to rip it in the first instance as it was on my laptop a few weeks back just before I killed it (waiting for Viao to replace)
Im now going to do the editing on my main pc
I also have another question,
I have a solid state video recorder which records to compact falsh in .avi but when I drag it in to editing software it puts the footage on the sound time line and not the video timeline. any ideas?
Cheers
Compress movies in Adobe Premiere the same as Windows Movie Maker
By ckeen in forum Newbie / General discussionsReplies: 3Last Post: 2nd Apr 2012, 22:39 -
Windows Movie Maker capture import to Premiere Pro
By burrenyoga in forum CapturingReplies: 5Last Post: 24th Aug 2010, 09:36 -
Windows movie maker to dvd
By bilbonvidia in forum Authoring (DVD)Replies: 2Last Post: 31st Jan 2008, 17:41 -
Youtube video: Premiere pro export and then use Windows Movie Maker?
By vid83 in forum Newbie / General discussionsReplies: 2Last Post: 13th Dec 2007, 21:59 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 22:18
