This query is not 100% on topic, but I think it fits here better than elsewhere.
Does anyone make, for lack of a better term, a powered usb cable?
Lots of usb host devices (pcs, portable dvd players, etc...) don't provide enough current over their usb bus to power some power-hungry "usb bus-powered" devices, such as external 2.5" hard drives. If you have two usb host ports available, you can use a usb Y cable which draws power from two host usb ports to supply a single usb mini port. It seems to me that since a usb (pre usb 3) consists of only four conductors, of which one pair is for data and one pair for power, that you could make a cable which carries the data between the host and device, supplies power over the other pair by mains of an AC-DC (home) or a DC-DC (car) transformer. It would be a little clunky, but it would work. I've searched, but can find nothing.
i use a powered usb hub. it has it's own ac-dc converter and provides power on the usb line even when the computer is off so you can recharge usb devices.
This is probably not what you're asking, but here's my two cents:
I was trying to transfer data from a desktop to a laptop using and external 3.5" drive. The laptop only had one (working) usb port , which couldn't quite power the drive. Solution: The drive already had a y-cable, so I plugged the other cable into one of those usb-ac adapters and it worked fine
This kind of thing
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
External power supply question (media center related)
By dbanimal in forum Media Center PC / MediaCentersReplies: 5Last Post: 16th Sep 2011, 00:49 -
What is this device? (rf in-out with power supply?)
By cynikalhedonist in forum CapturingReplies: 11Last Post: 23rd Mar 2011, 11:11 -
Power to external HDD
By jollyjohn in forum ComputerReplies: 8Last Post: 5th Jan 2010, 01:13 -
DVD Player with USB HDD (Non external Power) support
By fayewolf in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jan 2009, 21:10
Statistics
Newest guides
Latest tool updates
New media comments
