Staples did not have any Verbatim, TDK or Maxwell discs, so I tried their own store brand and Memorex, DVD-RW , 4X. The recorder would not format these discs. Is this because they are 4X and not 2X, or just plain crap, or both?
No problems with my depleting supply of old Verbatims and TDK's, so it is the discs.
Thread: JVC DR M10S, DVD-RW 4X, Media
Not as good as Verbatim & Sony, that's for sure.
The ONLY reliable re-writable media is Verbatim - period. Memorex makes the worst media I ever personally bought (before I knew any better). TDK used to be good in the past but is crap now. Sony in North America can be hit or miss. They use both the best and the worst manufacturers and it's a crap shoot as to which you get. Verbatim is the only company that consistently uses the highest quality manufacturers for re-writable DVDs.
Its probably both: the Staples house brand is made by CMC, which also makes 70% of all the other crap out there under different brand names, even some Verbatims. Aside from the occasional good Verbatim spindle, CMC media sends most older recorders into meltdown: they don't even recognize CMC media as a legitimate disc. The DRM-10 also predates 4x R/W by a wide margin, see if you can shop online for more of the 2.4x Verbatims that you know work well in your recorder. Or switch to DVD-RAM for your rewritable tasks, the DRM10 can use that too.
That JVC is only compatible with 2x RWs, unless there's been a firmware update to allow 4x discs.
Get some Sony 2x DVD-RW from Walmart, Walgreens, Target, or Staples.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
I got some Verbatim 2X on Ebay and they work fine.
Thanks.
JVC M10S DVD Recorder region code
By twoextreme4u in forum DVD & Blu-ray RecordersReplies: 0Last Post: 17th Aug 2006, 09:59 -
Value of a DVD Recorder JVC DR-M10S?
By scustalow in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Apr 2006, 03:49 -
JVC DR-M10S won't record on 16X DVD-R's. Firmware update?
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 1Last Post: 10th Mar 2006, 15:00 -
JVC SR-V10U (S)Vhs to JVC DR-M10S Dvd
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 9Last Post: 23rd Feb 2006, 20:15 -
JVC DR-M10S and which -RW media?
By alanb49 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 12th Dec 2004, 20:13
