i want to convert mkv files to avi hardsub, so i do things the easy way by using aimersoft video converter & cucusoft ultimate video converter. The problem is when the mkv files have more than one audio track (subs too), when i use aimersoft or cucusoft to convert the mkv files to avi hardsub, it automatically selects audio track 1 (there's no option to choose which audio track to keep and which to delete). So i am looking for a method to delete an audio track on a mkv file while keeping the other audio track and subs untouched.
EXAMPLE:
sailormoon.mkv
audio track 1 - english
audio track 2 - japanese
subtitle 1 - japanese
subtitle 2 - english
i want to keep "audio track 2 - japanese" with "subtitle 2 - english." that way converting the mkv to avi with aimersoft or cucusoft will be easier.
also, when making subtitles for movies, there seems to be ways to make subtitles "colorful and pretty, not just some boring Arial text." here's the question, if i need to re-encode the mkv files (and they contain the "colorful and pretty"), will i lose the subtitle design?
try mkvtoolnix.
May I suggest QAC? Although it does not listed correctly in the tools section and for long time it was featured with some spiteful offensive comments, among other conversions it does exactly that your looking for.
Especially if you have installed and properly configured the ffdshow filter, most likely you would not need to worry about the source MKV video format. Otherwise only mkv source with AVC video format will be successful.
How to convert mkv files and keep dual/multiple Audio Tracks?
By MrNathanF in forum Video ConversionReplies: 2Last Post: 19th Jan 2012, 10:34 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Multiple audio, subtitles, OGM, MKV & RMVB issues
By bkfng in forum ffmpegX general discussionReplies: 12Last Post: 16th Jan 2011, 23:05 -
How to convert MKV Matroska to Avi or Divx including audio tracks and sub
By s.elmagnifico in forum User guidesReplies: 0Last Post: 16th Aug 2008, 08:47 -
MKV conversion with multiple audio tracks???
By KrakaJap in forum Video ConversionReplies: 4Last Post: 26th Apr 2008, 18:25
Statistics
Newest guides
Latest tool updates
New media comments
