VideoHelp.com Forum
    I have a program holding 5 dvd's all of them I can play 4 I can copy but one has a flaw and will not completely copy.
    Is there a program which let me copy the imperfect dvd
    Thank you.
  2. Member Dv8ted2's Avatar
    Believing yourself to be secure only takes one cracker to dispel your belief.
  3. I've had success with DVDDecrypter set to ignore read errors and limit hardware retries to 2.
    Thanks both for replying.
    nic2k4:In the(DVDDecrypter) I have not such choices listed., It reported the error but let me no choice of ignore.
  5. Member fritzi93's Avatar
    DVDDecrypter: Tools -> Settings -> I/O.
    Under Options, check the box: "Ignore Read Errors". Also set " Software Read Error Retries". (I've found that more than about seven retries is futile).
    Pull! Bang! Darn!
    Thanks for all the suggestions but it did not work for me the file stopped, it did not ignore the error.
    "Isopuzzle" did overwrite the error but I did not know how to burn that file.
  7. Member t0nee1's Avatar
    Before burning it, I would suggest you run the ISO through DVDshrink, Ctrl+I keys..If it analyzes w/o error, then burn using IMGburn in 'Write' mode...
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
    t0nee1:
    "DVDshrink" did not help me because the dvd in question did have an error.
    "Isopuzzle" overwrite this error. But I wanted this dvd copied just the way it is, because it will play OK.
    I bought this program series (5 dvd's ) with one only having an error. I requested from the seller a replacement. The replacement sent showed the same error indicating that this series was produced in a duplicating machine.
  1. faulty DVD-R will not finalize
    By joecass in forum DVD & Blu-ray Recorders
    Last Post: 10th Nov 2009, 18:51
  2. Faulty Sony DW-U18A DVD Burner
    By Sakuya in forum DVD & Blu-ray Writers
    Last Post: 3rd Nov 2007, 02:16
  3. Burning DVD's Problem Faulty Disc's ???
    By Daftwood in forum Media
    Last Post: 1st Jul 2007, 16:44
  4. Replies: 1
    Last Post: 28th May 2007, 13:07
