I am having lots of problems with « What happen in Vegas…” b.r. My “normal” solution is rip with Makemkv then re-encode with handbrake. But Makemkv wont rip it, so I used anydvd trial to make an ISO. I then convert the ISO to mkv using MakeMkV (because handbrake wont read M2TS files) . I can play the mkv fine with the CCCP codec player, so the encryption is gone.
The problem I have now is handbrake chokes on the mkv, it says its opening but it wont do it. Its either very slow at opening or it does not support the video or audio codec inside the mkv. I am at work now, but I will inspect the mkv tonight to see what codec is used for the video and for audio’s and post it here.
Any other software (simple to install) could be use to re-encode the mkv?
Thread: BD+ encryption blue-ray
Try xvid4psp.
Thanks!
I will check it out. If it allow to make h264 with a custom resolution (1280x720) and a custom bitrate (2000) it may work. I also need 2 audio tracks and this is what is often stopping me from using a tool. There are tons of tool out there, but not a lot of them supports multiple audio tracks
Here is the file info and, omg, a 1536 kbps audio file...
That may be whats making hangbrake choke, because I know it can handle AVC and normal AC3 audio
General
Complete name : D:\BLUERAY\WHAT_HAPPENS_IN_VEGAS\WHAT_HAPPEN_IN_VE GAS.mkv
Format : Matroska
File size : 22.5 GiB
Duration : 1h 40mn
Overall bit rate : 31.9 Mbps
Writing application : MakeMKV v1.3_beta win(x86-release) build 797
Writing library : libmkv 0.6.3 (0.7.7/0.8.0) win(x86-release) build 797
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 40mn
Bit rate : 28.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.577
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 40mn
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Title : 3/2+1
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 40mn
Bit rate : 448 Kbps
Title : 3/2+1
Language : French
I finally did the re-encode:
1- AnyDVD HD : rip the BR to ISO image.
2- MakeMKV : convert the ISO to a mkv file. (no re-encoding)
3- PopCorn MKV AudioConverter : Re-encode the DTS to AC3 by doing a mkv to mkv conversion with the tool.
4- Handbrake : re-encode mkv to mkv (1280x720 2000kbps H264 video, AC3 audio tracks
Went from 26 gigs to 2.1gigs with no visible quality differences...
blue ray to blue ray
By slayer_of_all in forum Blu-ray RippingReplies: 7Last Post: 2nd Aug 2011, 13:37 -
Remove encryption (AACS) from Blu-ray.
By wisitch in forum Blu-ray RippingReplies: 1Last Post: 30th Jun 2010, 02:06 -
Blue ray Not so Blue ray
By PC2K1 in forum DVD & Blu-ray PlayersReplies: 25Last Post: 28th Nov 2007, 19:26 -
blue ray blue rot
By NICEBUD in forum Latest Video NewsReplies: 5Last Post: 21st Jun 2007, 12:01
