Hi all
I have a problem that i can't see to find a solution for.
I ripped my copy of Ronin last night to my Media Center HDD. I use TSmuxer to copy the m2ts file to my HDD (no compression)
In the process i usually leave all the eng pgs streams and just the eng audio.
My problem is that i found out that one of the pgs streams is actually subtitles for the non english speaking bit of the movie. IE forced subtitles.
I have never seen this before on blu-ray, usually these typs of subs are hard encoded into the video stream.
My questions is how do you force these to play in the m2ts container. I now i can use bdsup2sub to convert them but how do you ad them back into the m2ts file and force them to be displayed.
Am i correct in assuming that at this stage there is no codec that will natively display sup subtitles, they have to be converted??
Many thanks for you help.
I have K-lite codec pack installed.
m2ts files are played via Vista Media Centre. It sees it as a normal video file.
how am i able to force the subtitles to show for only for that movie. can they be read straight from the m2ts file (sup) or do i need to re encode the subtitles into another format.
I would really like to be able to just keep it all in the m2ts container and not have to have seperate files for the subtitles.
Thanks again for the assistant.
I don't think it's possible without reconverting and BURN in the subs. You could use xvid4psp, open the m2ts, load the subtitle, convert to a new m2ts, ts h264.
If i dont' try to hard encode them back in.
What are my other options for playing them if i convert the sup file to sub/idx and just leave the files in the same directory as the m2ts file.
When i play back the movie is there a way to force the subtitles to play via this method.
Help extracting forced subtitles from Sherlock Holmes (2009) blu-ray
By vtpeters in forum SubtitleReplies: 10Last Post: 14th Feb 2012, 17:32 -
Blu-ray Forced Subtitles
By jedisinclair in forum DVD RippingReplies: 4Last Post: 14th May 2010, 05:01 -
Forced subtitles english Blu Ray Avatar
By Modify_inc in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2010, 22:31 -
No forced subtitles on blu ray rip
By dreborn in forum Blu-ray RippingReplies: 2Last Post: 26th Oct 2009, 16:55 -
Edit M2TS file ripped from Blu-ray Disc
By seven_deuce offsuit in forum EditingReplies: 3Last Post: 22nd Sep 2009, 20:41
