VideoHelp.com Forum
    Hi
    My kids reset the password to Panasonic DVD-LS83 portable DVD Player and now can't remember it.
    We need to reset the password or reset to the factory settings.
    Can anyone help?
  2. VH Wanderer Ai Haibara's Avatar
    One thing you can try, for resetting DVD players to factory settings, is to unplug the player from the power outlet and leave it unplugged for at least a half hour. It doesn't work for all players, though.
    My aunt did the same. and like Ai Haibara said factory reset helped
    I tried what Ai Haibara said and still nothing. What is the factory reset?? I've tried everything? Help
    What am I doing wrong.
    I removed the battery overnight and left it completely unplugged. Nothing.
    Please help.
    Have you read the manual page 16 middle of the page? It says:
    You have forgotten your
    ratings password.
    While stopped, press and hold [<<] and ["] on the unit and then also press and hold [> ON] on the unit until
    “Initialized” disappears from the screen. Turn the unit off and on again. All settings will return to the default values.
    Thanks. You are right Thymej
  1. Replies: 3
    Last Post: 1st Aug 2011, 17:35
  2. Panasonic DVD - LS83
    By wraeththu in forum DVD & Blu-ray Players
    Last Post: 1st Aug 2011, 17:10
  3. Panasonic LS83 sound
    Last Post: 1st Aug 2011, 16:19
  4. Replies: 8
    Last Post: 23rd Feb 2009, 17:26
