Is there any way (when you convert) to change .ass subtitles' size and position in a .mkv without extracting them? Is there any directshow filter (directvobsub doesn't affect subtitles) or even a video converter that really supports reconfiguring .ass subtitles?
Thanks in advance , Jadas.
Avidemux has a ass/ssa subtitle plugin that can change size/position, so assuming you are hardcoding, this should work, but some builds are buggy you might have to play with a few versions before getting it to work properly
To do it perfectly/reliably , it takes 3 seconds to edit the .ass to change font size, just change the number in notepad (you don't even need aegisub to do this). It takes a few more seconds to change the position. If you have multiple styles / font sizes at different parts of the video it might take a bit longer, but still pretty easy to do.
Sorry for my late answer.
I know how to handle subs if I extract them, but the point is to convert without having to extract anything. What if I have attachments with multiple fonts?
I just try to find a way to adjust ass subtitles, like I adjust srt subtitles with directvobsub or subtitler filter in ffdshow.
Change on-screen position of PGS (SUP) subtitles
By YankeeFan in forum SubtitleReplies: 5Last Post: 24th Sep 2011, 16:07 -
.ASS subtitle is in sync but showing at the wrong position
By onlinepen in forum SubtitleReplies: 2Last Post: 9th Nov 2009, 04:48 -
Can you change bmp subtitles size without converting them first to text?
By Talayero in forum SubtitleReplies: 3Last Post: 9th Feb 2008, 11:43 -
Subtitles : lower position / change color?
By izzat in forum SubtitleReplies: 2Last Post: 25th Aug 2007, 10:21 -
Question: How to adjust the position of ASS subtitle format?
By FulciLives in forum SubtitleReplies: 2Last Post: 22nd Jul 2007, 00:24
Statistics
Newest guides
Latest tool updates
New media comments
