This seems to have started happening when I had to update Divx to its latest version. The AVI has all the info but the S2D output cuts out the last few minutes. Here is a log file to help.
-Del
svcd2dvdlog-20090320211743.txt
It is because you are using your I drive wich is FAT32.... FAT32 has a single file limit of 4GB and so the encoding stops when the ouput reaches that size....DeviceID: I:
FileSystem: FAT32
FreeSpace: 22.5 GB
Use one of your NTFS drives as output and you will be ok:
Or convert your I drive to NTFS.DeviceID: C:
FileSystem: NTFS
FreeSpace: 17.9 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 8.71 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 17.8 GBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Was an external drive made internal. Did not even think to check that. Will convert to NTSF later and try again. thanks
-Del
Cut-Edit Converted FLV download?
By ranchhand in forum Video StreamingReplies: 4Last Post: 15th Aug 2010, 09:33 -
Videos converted skip and are cut off
By gdreger in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 28th Dec 2009, 15:12 -
Last few min of AVI being cropped out
By Mr_Del in forum Video ConversionReplies: 1Last Post: 15th Mar 2009, 08:59 -
Converted avi files darker than originals (avi to mp4)
By Hal05154 in forum Newbie / General discussionsReplies: 3Last Post: 5th Mar 2009, 19:06 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
Statistics
Newest guides
Latest tool updates
New media comments
