I captured a video using windv and converted it to an iso using dvdflick for try #1 and avi2dvd for try # 2 and then burned it using imgburn onto a verbatim dvd. When both dvd's are played on either of my dvd players connected to the TV the picture is jagged when the camera is moved to point at a different position, but when it is played on my computer it is fine.
Any suggestions on what is causing this and could it be interlacing?
Thanks![]()
Thread: avi to dvd picture poor quality
Check the field order in your MPEG encoding. DV AVI is interlaced and bottom field first. It should be encoded that way for DVD.
i'd recommend using FAVC, then burn the result with imgburn.
open the video with FAVC and simply configure the things there. you can choose whether you use HC or QuEnc for encoding. i recommend you choose full-d1 and set the quality to high. you can choose whether you use HC or QuEnc for encoding. then click generate DVD.
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 12:00 -
Great Quality AVI, Poor Resolution Creating Assembled video in Studio 14
By japentz in forum Video ConversionReplies: 8Last Post: 5th Jul 2010, 19:34 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Poor picture from my tv to my dvd recorder - please help!
By mariabkbcards in forum DVD & Blu-ray RecordersReplies: 6Last Post: 27th Oct 2009, 21:44 -
DVP5990-37.. poor avi decompression playback quality?
By Gareee in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Jan 2009, 13:34
Statistics
Newest guides
Latest tool updates
New media comments
