I"m trying to convert some .mov files from my Aiptek camera, and ran across an article on the Net that said you can use TmpGenc. They made it sound so easy, but of course, it doesn't work that way.
I have the Quicktime reader vpa (whatever) plugin, but I'm getting a white screen - no picture or sound. I had changed the aspect, the frame rate from 60 to 30 (29.xx), etc- standard for DVD, but still no luck. Are there some other settings I"m overlooking?
THe quicktime reader is very old and does not support all movs. Maybe try something else to convert your movs like mpeg streamclip, avidemux, xvid4psp, winff . Or use mp4cam2avi and try make an avi from the mov. Or use quicktime alternative and be sure that tmpgenc uses directshow reading(increase the directshow priority in the settings).
I see. I downloaded RAD Video Tools, but it seems to export only as avi - rather slow. I'll check out your suggestions.
Quicktime - Blocky/Pixelated Playback of Mov files
By marcrp in forum Newbie / General discussionsReplies: 4Last Post: 7th Mar 2011, 09:17 -
joining MOV files with quicktime
By natty in forum Newbie / General discussionsReplies: 5Last Post: 30th May 2009, 09:18 -
.mov files from digital camera incompatible with QuickTime 7
By DavidCasillas in forum MacReplies: 34Last Post: 21st Nov 2008, 09:56 -
How to Convert Quicktime MOV Video Files to MPEG-2
By hiroprot in forum Video ConversionReplies: 8Last Post: 10th Nov 2008, 09:54 -
Suggestion for converting hundreds of mov quicktime files
By m021478 in forum Video ConversionReplies: 0Last Post: 15th Aug 2007, 15:16
