VideoHelp.com Forum
    Well, I am using FastDegrain for degraining but I also want to use TemporalDegrain with it, but at first I was having trouble with FFT3DFilter, but I fixed it, and now whenever I try to use TemporalDegrain I get this error:
    I've been trying to get this thing to work for hours , Please help!
  2. Member Soopafresh's Avatar
    I've seen that error before on occasion. I can't recall the fix, but try by installing a newer version of Avisynth for starters.
    Also, try the latest 1.X version of MVtools instead of version 2.
    My version of MVtools is from 8/7/08
    Don't run Fastdegrain and TemporalDegrain in the same script. TemporalDegrain is fantastic, the best (IMHO), but painfully slow. 1 FPS on most systems.
    And call it like this:
    TemporalDegrain(degrain=3)
    That will analyze 3 frames rather than the default 2 using MVtools
    Hmm, Still not working :/
    Do you think you can send me your plugins folder?
  4. Member Soopafresh's Avatar
    Mine is from the plugins folder found in AutoMKV
    Thanks, I'll try it out
    Question: I get them from the Filter folder, correct?
    Ok thanks for your help, A little modifications to FastDegrain and now I get the results I want. Thank so much for your help.
  1. Trouble Editing/Trouble Base Media?
    By SlickPen in forum Editing
    Last Post: 20th Mar 2011, 19:53
  2. Trouble with OE
    By alegator in forum Computer
    Last Post: 6th Feb 2009, 14:52
  3. PS/2 Trouble
    By gooberguy in forum Computer
    Last Post: 19th Jun 2008, 18:08
  4. Subtitle trouble.
    By novadragon849 in forum Subtitle
    Last Post: 2nd Dec 2007, 04:30
  5. Degraining the Blue Channel to Clean Up Video
    By Soopafresh in forum Restoration
    Last Post: 30th Nov 2007, 10:59
