VideoHelp.com Forum
  1. my tvix 6500 media player will play all the hd audio codecs accept true hd, i hear you can convert this to lossless so that i dont loose any of the hd quality can anybody give me a guide on how to do this please i have a bout 9 films that i cant play on my tvix because they all are true and i wont to keep the hd sound quality and not convert them to ac3
    Looking at the specs of the tvix, the only lossless format it accepts is flac. You can convert it but it will be huge. You can use eac3to to do this.
  3. Originally Posted by poisondeathray
    i have converted true hd to flac and lpcm but cannot join them in tsmuxer
    tvix can play mkv, so you are not restricted to .m2ts format. So you could put flac in mkv , for example
    Even so, tsmuxer should handle muxing lpcm no problems (not sure about flac). Are you using a current beta version?
  5. Originally Posted by poisondeathray
    i dont know what im doing wrong but i end up with the m2ts file and a meta file (the converted audio) but i cannot join these together in tsmuxer as a message comes up unsupported stream
    The meta file isn't the actual audio, it's basically a log
    Unless you used another method, the lpcm converted by eac3to isn't recognized by tsmuxer directly (header differences or something like that), so you need pcm2tsmu . Here is an illustrated guide: http://forums.afterdawn.com/thread_v...701752#4285687
    The other way is to use flac + video + mkv using mkvmerge. Same quality , smaller filesize because flac is ~1/2 the size, and mkv container overhead is ~5-7% smaller than .m2ts
  1. cant convert true hd to dts 1536
    By kevcampbell in forum Audio
    Last Post: 7th Sep 2009, 17:46
  2. AVI with DTS wont play - can I convert?
    By snadge in forum Audio
    Last Post: 29th Jul 2009, 09:41
  3. Replies: 13
    Last Post: 10th Mar 2009, 13:58
  4. Can't play ISO files with TViX M-6500A Media player
    By ralph snr in forum Newbie / General discussions
    Last Post: 6th Oct 2008, 16:59
  5. wmv file wont play nor convert
    By excitezone in forum Newbie / General discussions
    Last Post: 18th Dec 2007, 12:56
