In most respects this is a decent player but the sound is terrible.The last quarter of the sound bar does nothing and even with headphones and the sound up full you can still hear all the back ground noise.Does anyone have any ideas on how to increase the sound range?.
Thread: Panasonic LS83 sound
You aren't likely to find a way of increasing the volume as it's simply a function of the hardware. At least not in a simple way such as with a menu option. If you have an electronics background, you could likely open it up and tweak the audio circuit. But even then I wouldn't expect much to be gained, as it is likely just using cheap hardware.
Google is your Friend
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Panasonic DVD - LS83
By wraeththu in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Aug 2011, 17:10 -
Panasonic E25S dvd recorder sometimes no sound, sometimes the language is
By padraig in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th May 2010, 19:18 -
Frogot Reset password to play Panasonic DVD LS83
By ikecanada in forum DVD & Blu-ray PlayersReplies: 5Last Post: 24th Mar 2009, 23:36 -
Help, no sound from Panasonic DMP-BD35
By colt4523 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Dec 2008, 20:45
Statistics
Newest guides
Latest tool updates
New media comments
