ive had this dvd player as a backup player, i now want to use it but there is a problem i cant solve.
On the majority on dvd's i try to play, when the film starts it automatically puts subtiltes on and has no voice/speech sound just background noise. If i then restart the film with the subtitles off it still has no speech sound.
So basically on most dvd's i get no speech sound. Ive tried everything i can think of with the sound settings, its so fustrating as some older dvds play the speech sound fine so i dont think its a hardware problem.
please help
thanks
Thread: Vistron DHRB dvd recorder/player
Welcome to the forums, but you make the same mistake most new members make. You think that saying less is better than saying more and you are wrong. Need more info here.
Your problem sounds like a surround sound issue, but you didn't tell us if you have a surround sound setup, if you've verified that it works and so on. I'd guess that somehow you are getting only the back channels on some DVDs that use true surround sound. It might be a DVD player configuration issue, a problem with your surround sound set up, maybe a speaker wire problem, and so on. Hard to say, but hopefully this will point you in the right direction. If you don't have a surround setup than see if your DVD player has a configurable option to change the sound from 5.1 to stereo.
I know nothing about this player and its quirks as this brand isn't sold in the USA.
thanks for reply, i dont have a surround system. dvd player is linked to tv through scart thats it. it seems the discs with the no audio our the newer discs with sound 5.1. cant find anything in the manual or menu system to change from 5.1 to stereo. will keep looking thanks
What does this DVD player/recorder have others don't?
By wetcamelfood in forum Newbie / General discussionsReplies: 19Last Post: 5th May 2010, 15:34 -
Is there any DVD Player with FireWire output? (no recorder)
By Sean_ve99 in forum DVD & Blu-ray PlayersReplies: 24Last Post: 4th Jun 2009, 13:58 -
Multi Region Hack need for Vistron DVD-026HD - Ebuyer special!!
By droog1983 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Apr 2008, 05:12 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
upconverter dvd player/recorder recommendations...
By rubberman in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jul 2007, 15:36
Statistics
Newest guides
Latest tool updates
New media comments
