VideoHelp.com Forum
Results 1 to 13 of 13
    What is the type of paper called that are inserts for commercial DVD's?
  2. Member Xylob the Destroyer's Avatar
    If you're looking at printing your own inserts and the cases you have include the clear plastic overlay on the outside, you can use regular paper.
    The plastic cover makes 'em look just like the 'regular' covers.
    I don't know the technical term for the slick magazine type paper used for the 'real' thing though.
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
    would photo paper be the same?
    Most photo paper is thicker, and far more expensive, than the real thing. You might be able to find some budget glossy finish inkjet paper that would look OK.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  5. I use to use one I got from Rima.com. It was a thin matte finish paper with perforated edges so you can tear it out to exactly DVD case size. It gave excellent results but the perforated edges would often tear and jam in the printer.
    For home printing:
    Hammermill 28-pound (28lbs) Color Copy Paper (used in inkjet or laser).
    Color laser image will often look best (not from HP, though).
    The slick paper you refer to must be machine printed on a press, it won't be laser or ink.
    Photo paper is too thick. Special "DVD case" paper is a low-quality stupid gimmick.
  7. Mod Neophyte Super Moderator redwudz's Avatar
    Probably better in our Media Forum. Moving you.
  8. Member hech54's Avatar
    HP Brochure Paper.
    A little harder to find....but that is my preferred paper
    for the FEW insterts I require.
  9. Member Krispy Kritter's Avatar
    I use high-res ink jet paper, legal size. http://www.newegg.com/Product/Produc...82E16828103049
    Google is your Friend
    Your original post mentioned commercial DVDs. They don't use inkjet or laser printers. Usually, it is 4-color offset printing. There are a variety of paper stocks to choose from. Most commercial printing companies (US Press is a good one, for example) can mail you a packet of samples that can help you choose the weight (thickness) and surface finish of the printed works.
    Most any good 24 pound paper will do the trick. I get it at Staples. Reasonable price & good quality.
    http://www.polylinecorp.com/category-three.asp?DVD=Inserts-|-CD-and-DVD-printable-insert-|-for-DVD-Cases
    I've been dealing with polylinecorp.com for years. I get my cases and bubblepack mailer from them.
  13. Member ntscuser's Avatar
    160GSM card from Staples.
    Anything thinner and the ink will print through.
    The friend who put me on to it worked in the printing industry for decades before he started designing his own covers.
  1. DVD cover size and paper
    By Digiface in forum Media
    Last Post: 14th Oct 2011, 08:41
  2. What's some good paper for DVD inserts?
    By slayerbizkit in forum Media
    Last Post: 21st May 2011, 09:01
  3. Pre-perforated paper for DVD case labels?
    By stantheman1976 in forum Newbie / General discussions
    Last Post: 27th May 2009, 12:40
  4. DVD Covers
    By Beefer in forum Mac
    Last Post: 15th Nov 2007, 14:17
