I have been buying cheap blank DVD's at poundland 4discs for a £1 by signalex. I didn't think much about it because I never have a problem when burning .VOB files onto them, but lately my girlfriend says the DVD's I had given her keep skipping when playing via the PS2, it sounds like a typical PS2 problem I had before but I can't help but wonder whether it was because of the DVD disc, its it better to buy a known brand like TDK?
Thread: Blank DVD Disc Brand?
PS2 has always been a problem child with burned discs. Better quality discs will reduce the problem, but you may have to try a couple of different brands before you find the right one. I would start with verbatims and TYs.
does it really make much of a differnce between a cheap disc and an expensive one like TDK?
I looked on ebay, they have some 100pk for £20 by titanium, although they are DVD discs, they don't really say anything about them being suitable for DVD media.
Getting good burns means find the right blanks that will burn well in your burner, and playback well on your player. There is no absolute right answer. As a general rule, better branded media burns better, lasts longer, and plays better. My personal experience ? Cheap media is generally shit.
TDK discs are expensive SHIT....Titanium are even WORSE.Originally Posted by Nitro89
Go To:
SVP Blank Disc Shop (UK)
Taiyo Yuden silver topped 8x or 16x discs.
Done.
http://svp.co.uk/product/taiyo_yuden...d_r_taiyo_y013
i just bought a 100pk of verbatims dvd discs for £20
also, I want to know, if the disc has the brand name printed on it, am I still able to vreate a picture disc on top or use lightscribe?
You definitely CANNOT use these for Lightscribe. Lightscribe discs are completely blank with only a single color on the printable side. They have a special surface and are branded as being Lightscribe discs.Originally Posted by Nitro89
By "picture disc" I think you are asking can you print to the surface. I don't think so. The only discs I've ever used that a printer can write to have also been blank.
oh well, just going to use the old pernament marker routine
DVD+r shows up as blank disc
By garylanders in forum MediaReplies: 9Last Post: 25th Nov 2011, 05:22 -
Help...Blank DVD-R disc shows region 8...
By Praetorian_Prefect in forum Newbie / General discussionsReplies: 9Last Post: 23rd Jun 2011, 23:17 -
How to Compress Four to Five movies onto One DVD-R 4.38gb blank disc ?
By 351shaker in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2011, 06:10 -
C 1300 disc is dirty error on NEW blank dvd's
By rrtbusa in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd May 2010, 08:25 -
software needed to identify which brand of blank DVD I'm using ?
By beammeup in forum MediaReplies: 3Last Post: 7th Dec 2009, 04:50
