Hello
i tring to compile an avi file with an str file into an m4v file with subtitle
i try doing it with ffmpeg but if i choose an ouput ipod compatible
the checkbox to integrate subtitle is not available
is that normal or i miss someting ?
recap
with ffmepg i try to do
avi + srt ==> m4v(+srt)
regards
nicolas
Thread: ffmepx ipod and subtitle
For iPod mp4 files, you have two choices for subtitles, as the iPod doesn't support soft subtitles.
1/ Use QuickTime Pro and Perian to save both in one .mov file, and convert that to mp4 using the iPod preset in ffmpegX, or
2/ Convert twice: once with XviD mencoder for hard-subbing, then another time to convert to iPod mp4.
hi
thanks for the answer
i assume is the same thing with iphone ?
regards
nicolas
I have an iPod Touch which is basically the iPhone without the phone and camera and it does NOT support soft subtitles.
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 00:04 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 20:56 -
iPod dock picking up interference from iPod
By snadge in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 09:37 -
any Ipod experts? way to restore lost music on Ipod
By scustalow in forum Portable VideoReplies: 2Last Post: 9th Jul 2008, 00:56 -
Videora iPod Converter (DVD to IPOD)
By Denman007 in forum DVD RippingReplies: 0Last Post: 15th Aug 2007, 19:06
