What happens to a DTS audio stream when extracting in VobSet mode? One of the features you mentioned for vobsets reads 'Handle DTS/LPCM audio'. What kind of handling is meant here? Is there any re-encoding done or just merging the vobset and extract the Mpeg from the vob-container (that's what i need)?
Thanks for your help
Thread: VOB2MPG Pro and DTS audio
In VOBSET mode DTS is handled by choosing the following setting:
And so vobs with dts are handled but the audio is encoded to AC3. This is new to v3 as v2.5 would just make a mess of DTS inputs.
If you need to retain the DTS streams untouched - use IFO mode.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Any chance this can be done in IFO mode as well? I have a DVD with DTS that I want converted to AC3 because the devices I want to play the MPG on do not support DTS. I can't currently use VOBSET mode because it doesn't seem to work with Windows 7 Pro due to ffmpeg crashing.Originally Posted by ChrissyBoy
VOBSET mode works fin on Win 7..... Can you post a log from a failed run?
I will post a log file as soon as I can, but in the mean time is it possible to convert a DTS DVD to AC3 in IFOMODE?
Intel Core i7 920
Windows 7 Pro
VOB2MPG Pro: no audio
By stevie99 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 7th Mar 2012, 00:50 -
Getting wrong audio stream with VOB2MPG Pro 3.2.2000
By mwebb in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 20th Aug 2011, 13:45 -
no audio in vob2mpg pro
By p.hisada in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 29th Mar 2010, 11:28 -
VOB2MPG PRO audio sync issue
By wriggley in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 5th Feb 2010, 16:19 -
from vob2mpg into MAC Final Cut Pro - no audio
By finedesign in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Jan 2010, 03:43
