VideoHelp.com Forum
Results 1 to 9 of 9
    Hello,
    I have a large TV but it's NOT HD (It's relatively modern, was purchased just before HD/plasmas became all the rage). I'm looking to buy a dvd player, preferably with DivX capacities, but I can't seem to figure out what DVD players will be compatible with a non-hd television. I live in Canada. Do upconverting dvd players need to be used with a hdtv (bestbuy only offers upconverting dvd players it appears)?
    Does anyone know of a DVD player that'll play multiple formats (hoping to find one that plays divx) and work with a non-HD television? Sorry to be such an imbecile but try as I might I can't seem to google my way out of this bind. Thanks.
  2. Upconvert players don't have to be used with an HDTV, they all have analog outputs.
  3. Always Watching guns1inger's Avatar
    DVD is essentially an SD device. Upscaling is a bonus. I have yet to see a DVD player that doesn't support SD televisions. I suspect the even most Bluray players support them as well. Anything with component or s-video outputs will do you (assuming your TV has at least s-video in)
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. Member edDV's Avatar
    I was surprised my latest Philips 5992 DVD player lacked an S-Video output.
    If your analog TV is a late model, it may have an analog component input (Y Pb Pr). Most all DVD players have these outputs and this is your best option. Analog component for this type of TV should be set to 480i (either 4:3 or 16:9). If your TV lacks this input, make sure the DVD player you choose has next best S-Video out.
    http://www.kiva.org/about
  5. Member victoriabears's Avatar
    Places like Wal Mart and Canadian Tire still stock non up converting dvd players, and they are cheaper too.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
    Hrmm, okay well thank you for the assistance. On Best Buy it seems to indicate that some of their players aren't compatible, and not a single DVD player is marketed to anyone without an HDTV. If I ended up buying one that was less than perfectly compatible are there any convertors/cables I could invest in to salvage the buy, or should I be weary?
    I wish I could offer more specs, however, my tv's in storage until moving day. I vaguely remember, yellow/white/red coaxials. Although I can't say if that's it because I ignored any plugs which weren't of use to me in the past.
    Any recommendations on a specific DVD player to track down? I'm sure you'd have much better advice than anyone in any of the retail outlets selling them. I would like the capacity to play .avi files (as aforementioned) if possible.
    Thanks Again. I really appreciate it.
    Victoriabears, did you happen to notice if any of the prehistoric players Walmart/Can Tire had played DivX?
  8. Member victoriabears's Avatar
    can tire have a web site and wal mart sell, at least herem Philips ones that do divx.
    As has been said, most dvd players that up convert will do SD, I am not convinced about the benefit of S Video or even component, but that's my opinion.
  9. Member edDV's Avatar
    RF outputs (Channel 3/4) have disappeared from most current DVD players*.
    I have yet to see a DVD player without basic composite video (Yellow) and base audio (Red,White).
    A better connection is S-Video instead of composite and/or digital audio instead of red/white.
    Better yet is 480i analog component Y,Pb,Pr (Green, Blue, Red).
    Beyond that there may be progressive 480p analog componet and/or HD upscale 720p, 1080i capability on analog component or HDMI connectors. Ignor these for your current TV.
    * You can buy an external modulator that converts Yellow/Red/White to RF for the older TV sets.
  1. Need help finding replacement for Cyberhome player
    By canofhumdingers in forum DVD & Blu-ray Players
    Last Post: 22nd Mar 2012, 20:15
  2. Tape player that does subtitles, finding one?
    By jmthomas in forum Newbie / General discussions
    Last Post: 16th Dec 2011, 21:16
  3. Replies: 13
    Last Post: 30th Nov 2009, 21:33
  4. Replies: 11
    Last Post: 9th Apr 2009, 16:07
  5. Need help finding a VCR/DVD Combo Player that is CT-2 Friendly
    By elling in forum Newbie / General discussions
    Last Post: 6th Sep 2007, 18:39
