I have video MKV format when I try to extracted the subtitle it gives me the this:
file has no recognised subtitles tracks
the video was rmvb format then I converted to AVI then MKV
what should I do?
thanks in advance
Thread: MKV Subtitle
Are you sure it contain soft subtitles and not permanent/hard subtitles?
And if you made the mkv yourself did you then add a subtitle track to the mkv?
I don't know anything about the soft and hard subtitle
can u tell me about them
what should I do if it is a soft or hard subtitle?
I did't made it my self
'Soft' subtitles are separate streams in a video, and can be turned on or off at will. 'Hard' subtitles are encoded into the video itself - becoming a part of the video data - and can't be turned on or off.
I'm guessing your subtitles are encoded into the video itself, especially since you converted from RMVB - and I don't think RMVB supports external subtitles/subtitle streams. (I could be wrong, though.)
(Baldrick: Should the hard/soft subtitle terms be added to the Glossary? I don't know what words/phrases should be used to 'activate' them in posts, though.
so can I extract the hard subtitle?
if i can tell me how please?
There are utilities that will attempt to OCR subtitles from hard-subbed sources, but it takes a bit of work (from both the program and the user), and I don't know how well they work, as I've never tried it. You might experiment with AVISubDetector and Subrip (I can't remember if there's an OCR utility included in the VobSub package), but those may require you to use an AVI stream to attempt to read the subtitles.
An alternate (easier
) option would be to search for the subtitles online.
MKV to DV + subtitle
By Pie in forum Video ConversionReplies: 6Last Post: 14th Apr 2012, 03:10 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 2nd Mar 2012, 15:25 -
MKV And subtitle > help
By sat-jokar in forum SubtitleReplies: 10Last Post: 29th Dec 2010, 11:49 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
Subtitle with MKV problem
By maccool111 in forum SubtitleReplies: 3Last Post: 19th Apr 2010, 04:37
