I am getting a strange error when launching VOB2MPG on my Vista 64 machine.. Below is the error i am receiving. I searched the forums but couldn't find much to help me out. Any help would be greatly appreciated.. I have tried to uninstall and reinstall and have no other codec packs that would be messing with ffmpeg..
Version: VOB2MPG PRO
Build: 3.0.0021
Type: System.Runtime.InteropServices.COMException
Source: System.Windows.Forms
Message: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
InnerException:
StackTrace: at System.Windows.Forms.UnsafeNativeMethods.CoCreateI nstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
at System.Windows.Forms.AxHost.CreateWithoutLicense(G uid clsid)
at System.Windows.Forms.AxHost.CreateWithLicense(Stri ng license, Guid clsid)
at System.Windows.Forms.AxHost.CreateInstanceCore(Gui d clsid)
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.AxHost.EndInit()
at VOB2MPG_PRO.x2f5590cb48bb0c53.x85601834555fb7d5()
at VOB2MPG_PRO.x2f5590cb48bb0c53..ctor()
at VOB2MPG_PRO.x2f5590cb48bb0c53.xc447809891322395(St ring[] xce8d8c7e3c2c2426)
Results 1 to 14 of 14
What folder are you installing in?
just installed to the default location c:\VOB2MPG PRO
One more thing.. I just installed it on my other Vista 64 machine and I am getting the same error. Works fine on my three other Vista 32 machines.. Maybe Vista 64 issue?
Can you try reinstalling but running the setup as administrator? (I think that is a requirement on Vista 64)
I had just downloaded and installed the pro version also and I get the exact same error message.
In my case I'm running Vista Home Prem 64bit
I had installed as the administrator onto a seperate drive from my c:\programs
Used the same approach as SVCD2DVD for which runs fine for me.
Randalliser
Can you drop me an email and i will send you a 64bit build to try.Originally Posted by RandalliserSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Just to let you know that I also have Vista Ultimate 32bit version and it had installed fine on this machine. I will send you an email in order to try the 64 bit version you have.
Regards
Okay I had just installed your released version. I get the exact same error message.
As added info, it had installed fine. It is when I click on the program to start the registration the error message immediately pops up.
On a second note, for the version I had installed on Vista Eltimate 32 bit, I tried to convert one of the SVCDtoDVD that I had done back to MPG files. The conversion went very well (and quick by the way), but I had a problem when trying to play back the MPG file. Using Nero 9, it loaded up but with no image and you heard sounds for a couple of seconds then it would stop. Do you know if I need an extra codec for nero. The mpg file had played fine using Windows Media Center though.
Regards
Sorry - i am being a numpty today.... I will send another build to the same email address as before.Originally Posted by Randalliser
ChrisSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Okay tried the lattest release. Did not work but received a different error message. Here it is:
Build: 3.0.0021
Type: System.IO.FileNotFoundException
Source: VOB2MPG
Message: Could not load file or assembly 'AxInterop.CodeLock, Version=1.0.0.0, Culture=neutral, PublicKeyToken=2b63f0abbaf93e6a' or one of its dependencies. The system cannot find the file specified.
InnerException:
StackTrace: at VOB2MPG_PRO.x2f5590cb48bb0c53.x85601834555fb7d5()
Regards
JOY - the last release version you had sent worked perfectly.
Even Nero 9 that is also installed on my main computer worked fine with the extracted MPG's. I'll also install this release on my Ultimate 32bit computer in order to see if Nero 9 works okay.
Regards
Excellent. I have updated the download with this new version. Same build just different Installer config for our 64bit friends.
Thanks for the heads up and help resolving this.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
[Guide] Using DMFS on Windows7 64bit (with Sony Vegas Pro 10 64bit)
By Luponius in forum User guidesReplies: 8Last Post: 8th Oct 2011, 12:16 -
VOB2MPG PRO command line not processing in 64bit Windows 7
By BJTHEDJ in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 6th Dec 2010, 15:53 -
VOB2MPG Pro Interface Change Causes Error
By JCJFH in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 27th Nov 2009, 20:08 -
VOB2MPG Pro V3.0.0024 error
By SWBisbee in forum Newbie / General discussionsReplies: 1Last Post: 3rd May 2009, 16:23 -
Capture Card for Vista Ultimate 64bit
By cgcarter in forum CapturingReplies: 1Last Post: 5th Dec 2008, 11:24
