VideoHelp.com Forum
    Can anyone out there tell me if my Lite-on LVW-5045 will automatically change time setting when British Summer Time comes in next weekend?
    If not, I will have to adjust my recording times to suit the change in the real time!!!!!
    Am going away tomorrow so this request has some urgency and would be very grateful for any knowledgable responses.
    Ta.
    Hi pmitch, the 5045 doesn't support time changing, you need to go into setup and change the clock manually on the day(s) time changes occur. You don't need to change your timer settings, just your clock.
    I suspect the question is that you'll be away when the time change occurs, then absolutely, you need to change your timers. It's a PITA to have to change them all back and adjust the clock when you come back but that's basically your only option with the 5045.
    Thanks,
    you are a star!
  1. Macrovision Firmware Lite-on LVW-5006
    By drewbert73 in forum DVD & Blu-ray Recorders
    Last Post: 6th Aug 2011, 15:21
  2. Liteon LVW-5045 replace DVD drive, project started...
    By dainova in forum DVD & Blu-ray Recorders
    Last Post: 5th Apr 2011, 06:04
  3. Upgrade Liteon lvw-5045 to 400G successfully
    By totoro168 in forum DVD & Blu-ray Recorders
    Last Post: 6th Mar 2011, 20:06
  4. LITEON LVW-5045 cannot read DVD-R disks
    By elfie-gow in forum DVD & Blu-ray Recorders
    Last Post: 29th Jan 2011, 16:58
  5. LiteOn Lvw-5045 (UK - English)
    By cubud in forum DVD & Blu-ray Recorders
    Last Post: 10th Jun 2007, 14:05
