I just recently brought my self a blu writer, its just wonderful.
I have my wedding film span over a few dvds so i ripped them on to my computer, and compressed them aswell to i think is mpg4 for ps3 or divx not sure what codec.
But i was wondering if i keep the ripped mpg4 files how the are without changing the format and make menus for it on the blu ray disc so that they will work on ps3, like the tmpeg enc menu creator that had divx support for dvds.
Can somebody help me, and put me in the right step on what software to use and to be ps3 compatible.
Thank You![]()
Thread: Info Required Blu-ray menus
DVDs use mpg2, which is also compliant for Bluray. These can be authored with Tmpgenc Authoring Works 4 and burned to Bluray with Imburn.
If you encode with H264 then you could look at multiAVCHD. Look carefully at the menus you will have to live with though.
Thank You for the info, i will give both software a try, hopefully i get it to work.
Once Again Thank You.
Blu-Ray angle Info tool
By Oktober in forum Blu-ray RippingReplies: 7Last Post: 22nd Jul 2011, 05:07 -
Scenarist basic blu-ray without menus?
By uridylylator in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Apr 2011, 03:46 -
info on lg bd555c blu-ray player
By Regor21 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Mar 2011, 15:57 -
Adding menus to a remuxed Blu-Ray
By ITISRAVI in forum Blu-ray RippingReplies: 0Last Post: 17th Nov 2010, 09:27 -
Need additional info about re-encoding Blu-Ray
By snipingkid in forum Blu-ray RippingReplies: 7Last Post: 23rd Apr 2009, 13:12
Statistics
Newest guides
Latest tool updates
New media comments
