I ripped a 2 hour home DVD to AVI, edited it in Premiere Pro to take out unwanted scenes, now I want to convert to DIVX or XVID. I tried Divx converter, but it doesn't like the 20 gig file that PPro spit out (export:movie). I don't have the disc anymore and I'm stuck with the AVI that I converted it too from the disc. Other wise I would use FairUse wizard. So at this point, I was considering converting back to MPEG2, then using DVDLabPro to convert back to VOB's, than convert to ISO so FUW can convert to divx or xvid. I know there has to be an easier way. Thanks
Export to avi divx or xvid directly in premiere?
Is there a divx codec for PPro?
Divx Converter probably just needs a VFW DV decoder like Cedocida. I'm guessing this because you talk of 2 hours of video being 20 GB and you're using Premiere Pro.
But if you simply install Divx or Xvid you should be able to export as Divx/Xvid AVI directly from Premiere Pro. I believe it can export AVI with any VFW encoder.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 24Last Post: 31st Jan 2012, 07:07 -
Best DVD to DivX / Xvid avi
By spidey in forum DVD RippingReplies: 6Last Post: 3rd Jul 2008, 14:20 -
What FREE software for .avi DivX Xvid etc to DVD do you use? and encoders?
By mcv2008 in forum Newbie / General discussionsReplies: 10Last Post: 28th Jun 2008, 10:08 -
What's best to burn to DVD: XVID, DIVX, AVI?
By peterj in forum Authoring (DVD)Replies: 3Last Post: 17th Jan 2008, 07:35 -
I need to convert dvd into avi!not xvid or divx!
By picky2112 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 02:22
Statistics
Newest guides
Latest tool updates
New media comments
