Hello there.
I'm trying to split video and convert it into flv. Got next:
[root@gt57 ~]# ffmpeg -y -ss 0 -t 22 -async 1 -i video.wmv -acodec mp3 video.flv
FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
configuration: --prefix=/usr --libdir=/usr/lib --mandir=/usr/share/man --incdir=/usr/include/ffmpeg --enable-libmp3lame --enable-libogg --enable-libvorbis --enable-libogg --enable-libtheora --enable-libfaad --enable-libfaac --enable-libgsm --enable-xvid --enable-x264 --enable-liba52 --enable-liba52bin --enable-pp --enable-shared --enable-pthreads --enable-gpl --disable-strip
libavutil version: 49.4.0
libavcodec version: 51.40.4
libavformat version: 51.12.1
built on Jun 4 2007 11:02:12, gcc: 4.1.1 20070105 (Red Hat 4.1.1-52)
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 29.97 (30000/1001)
Input #0, asf, from 'video.wmv':
Duration: 00:22:57.4, start: 10.000000, bitrate: 1636 kb/s
Stream #0.0: Audio: 0x0162, 44100 Hz, stereo, 128 kb/s
Stream #0.1: Video: wmv3, yuv420p, 700x394, 1500 kb/s, 29.97 fps(r)
Output #0, flv, to 'video.flv':
Stream #0.0: Video: flv, yuv420p, 700x394, q=2-31, 200 kb/s, 29.97 fps(c)
Stream #0.1: Audio: mp3, 44100 Hz, stereo, 64 kb/s
Stream mapping:
Stream #0.1 -> #0.0
Stream #0.0 -> #0.1
Unsupported codec (id=0) for input stream #0.0
When I user " -an " flag I got FLV but without audio stream.
What should I do to get video+audio FLV from WMV?
Thanks for advice,
Dmitry.
Change -acodec mp3 to
-acodec libmp3lame
Not sure why -acodec mp3 works for you.
Says that your wmv stream has an unsupported audio codec by ffmpeg.
Does this file playback with mplayer? If so, you can dump the audio stream with mencoder and import it into ffmpeg.
mplayer -vo null -vc null -ao pcm:fast:file=audio.wav video.wmv
ffmpeg -y -ss 0 -t 22 -async 1 -i video.wmv -an -i audio.wav -acodec libmp3lame video.flx
-an may or may not be needed.
Your ffmpeg version is also quite old. built on Jun 4 2007 11:02:12, gcc: 4.1.1 20070105 Perhaps an update could fix the issue as well.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
Yes, this file playback with mplayer.
Tried to change acodec variable -acodec libmp3lame but failed. Got Unknown codec 'libmp3lame'. "-acodec mp3" works fine with some wmv files.
Can it be because of variable bitrate?
-acodec defines the encoding codec. Your ffmpeg has --enable-libmp3lame, but if you pass -acodec libmp3lame it failsOriginally Posted by rolikoff
What does mplayer say the audio is?
I tried your command with an wmv I have -Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 44100 Hz, 2 ch, s16le, 160.0 kbit/11.34% (ratio: 20005->176400)
Selected audio codec: [ffwmav2] afm: ffmpeg (DivX audio v2 (FFmpeg))
Then with -acodec libmp3lameCode:ffmpeg -y -ss 0 -t 22 -async 1 -i video.wmv -acodec mp3 video.flv FFmpeg version SVN-r17651, Copyright (c) 2000-2009 Fabrice Bellard, et al. configuration: --prefix=/usr --mandir=/usr/man --disable-debug --enable-shared --disable-static --enable-swscale --enable-postproc --enable-pthreads --enable-libfaac --enable-libfaad --enable-libfaadbin --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-gpl libavutil 49.15. 0 / 49.15. 0 libavcodec 52.20. 0 / 52.20. 0 libavformat 52.30. 1 / 52.30. 1 libavdevice 52. 1. 0 / 52. 1. 0 libswscale 0. 7. 1 / 0. 7. 1 libpostproc 51. 2. 0 / 51. 2. 0 built on Feb 27 2009 17:38:03, gcc: 4.2.4 Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 30.00 (30/1) Input #0, asf, from 'video.wmv': Duration: 00:10:19.23, start: 1.579000, bitrate: 2067 kb/s Stream #0.0: Audio: wmav2, 44100 Hz, stereo, s16, 160 kb/s Stream #0.1: Video: wmv3, yuv420p, 640x480, 1900 kb/s, 30 tbr, 1k tbn, 1k tbc Unknown encoder 'mp3'
I'd try to update your ffmpeg build. It's getting close to being 2 years old. Something screwy with the -acodec errors as well.Code:ffmpeg -y -ss 0 -t 22 -async 1 -i video.wmv -acodec libmp3lame video.flv FFmpeg version SVN-r17651, Copyright (c) 2000-2009 Fabrice Bellard, et al. configuration: --prefix=/usr --mandir=/usr/man --disable-debug --enable-shared --disable-static --enable-swscale --enable-postproc --enable-pthreads --enable-libfaac --enable-libfaad --enable-libfaadbin --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-gpl libavutil 49.15. 0 / 49.15. 0 libavcodec 52.20. 0 / 52.20. 0 libavformat 52.30. 1 / 52.30. 1 libavdevice 52. 1. 0 / 52. 1. 0 libswscale 0. 7. 1 / 0. 7. 1 libpostproc 51. 2. 0 / 51. 2. 0 built on Feb 27 2009 17:38:03, gcc: 4.2.4 Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 30.00 (30/1) Input #0, asf, from 'video.wmv': Duration: 00:10:19.23, start: 1.579000, bitrate: 2067 kb/s Stream #0.0: Audio: wmav2, 44100 Hz, stereo, s16, 160 kb/s Stream #0.1: Video: wmv3, yuv420p, 640x480, 1900 kb/s, 30 tbr, 1k tbn, 1k tbc Output #0, flv, to 'video.flv': Stream #0.0: Video: flv, yuv420p, 640x480, q=2-31, 200 kb/s, 90k tbn, 30 tbc Stream #0.1: Audio: libmp3lame, 44100 Hz, stereo, s16, 64 kb/s Stream mapping: Stream #0.1 -> #0.0 Stream #0.0 -> #0.1 Press [q] to stop encoding frame= 2255 fps= 253 q=31.0 size= 1487kB time=8.91 bitrate= 808.3kbits/sLinux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
FFMPEG decoding WMV to FLV problems
By motorg in forum Video ConversionReplies: 3Last Post: 10th Aug 2009, 21:30 -
[Help] wmv to flv with ffmpeg
By Nightslk in forum Video ConversionReplies: 2Last Post: 4th Aug 2009, 12:52 -
wmv to flv - 3 possible conversion with ffmpeg- difficult choice
By bmb in forum Video ConversionReplies: 0Last Post: 1st Oct 2007, 15:00 -
Need a little help here (wmv/mov to flv with ffmpeg)
By yeauxyo in forum Video ConversionReplies: 1Last Post: 9th Jul 2007, 23:08
Statistics
Newest guides
Latest tool updates
New media comments
