I'm sure you know DVDFab's profiles can be edited to a specific PVP, just recently (unofficially) found out so can Wondershare's. However, I'm trying to make a Divx/Xvid avi for the PMP 120, and am trying to get everything right so the converters will convert directly to the avi (so as to keep the resume capability). Right now, here's a video converted using Video Vault (info from KMplayer). Don't mind the filename
C:\Documents and Settings\Shilar\My Documents\DVDFab\generic\Video Vault\2 Chicks No Dicks 2 Scene 5\2 chicks No Dicks 2 Scene 5.avi
General
Complete name : C:\Documents and Settings\Shilar\My Documents\DVDFab\generic\Video Vault\2 Chicks No Dicks 2 Scene 5\2 chicks No Dicks 2 Scene 5.avi
Format : AVI
File size : 351 MiB
Duration : 23mn 28s
Overall bit rate : 2 089 Kbps
Video
Format : MPEG-4 Visual
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 23mn 28s
Bit rate : 1 949 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4/3
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.212
Stream size : 327 MiB (93%)
Title : Video
Writing library : DivX 1257
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 23mn 28s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 21.5 MiB (6%)
Alignment : Split accross interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Title : Audio
Right now, here's what I get from DVDFab:
C:\Documents and Settings\Shilar\My Documents\DVDFab\pvp\AH_MY_GODDESS_VOL2\AH_MY_GODD ESS_VOL2.Title10.DVDRip.avi
General
Complete name : C:\Documents and Settings\Shilar\My Documents\DVDFab\pvp\AH_MY_GODDESS_VOL2\AH_MY_GODD ESS_VOL2.Title10.DVDRip.avi
Format : AVI
File size : 1.67 GiB
Duration : 2h 1mn
Overall bit rate : 1 962 Kbps
Writing application : Lavf52.17.0
Video
Format profile : Simple@L1
Codec ID : DIVX
Codec ID/Info : Project Mayo
Codec ID/Hint : DivX 4
Duration : 2h 1mn
Bit rate : 1 820 Kbps
Width : 640 pixels
Height : 480 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.198
Stream size : 1.55 GiB (93%)
Writing library : Lavc51.60.0
Audio
Format : MPEG Audio
Codec ID : 55
Codec ID/Hint : MP3
Duration : 2h 1mn
Bit rate : 128 Kbps
Stream size : 111 MiB (7%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.72 video frame)
Writing library : LAME3.97
Would you like me to post the profile too, or is this all needed? Let me know.
Results 1 to 1 of 1
MKV: Merely Krappy Video.
Subbers, a request from an avid viewer: Either don't use mkv, or supply avi or mp4 as an alternative.
For those frustrated with converting MKV: http://www.immortalmusic.net/mkv/
Wondershare ultimate video converter 5.7.4 cannot use GPU encoding
By jones24 in forum ComputerReplies: 0Last Post: 4th Mar 2012, 15:48 -
How can I convert MKV profile high@5.1 to MKV profile 4.1 ?
By utahmar in forum Video ConversionReplies: 13Last Post: 7th Jan 2012, 15:01 -
Wondershare DVD Ripper?
By Loader09 in forum DVD RippingReplies: 8Last Post: 25th Jan 2011, 17:00 -
Invalid DVD folder in Wondershare DVD Ripper after using DvdReMake
By doofuz in forum DVD RippingReplies: 30Last Post: 2nd Dec 2010, 09:39 -
Wondershare DVD slideshow issues
By ashort515 in forum Newbie / General discussionsReplies: 0Last Post: 28th Jun 2008, 23:39
